SOLD. 2003 Tacoma DCSB TRD 4x4
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by digitalferg, Jan 25, 2021.
Thread Status:
Not open for further replies.
  1. Jan 25, 2021 at 3:24 PM
    digitalferg
    digitalferg [OP] Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    2003 Tacoma DCSB TRD 4x4, Supercharged, 5-spd swap, 4.30s, manual hubs, 160k miles
    Ready to move on from this Tacoma. I previously owned it from 2016-2017, sold it to a guy in Cal, missed it, bought it back in 2020, and it's just not working for what I need now.
    SOLD
    The Truck:
    • 2003 Toyota Tacoma TRD DoubleCab
    • Radiant red exterior
    • Gray fabric interior
    • 160k miles
    • TRD e-locker rear
    • Supercharged w/TRD 7th injector kit
    • 5-speed manual swap
    • 4.30 diff gears
    • manual front hubs
    • 3G SR5 4Runner front seats
    • Clean title in hand
    Modifications etc:
    • Supercharger added at 95,450 miles. was a used SC with ~8k miles on it. Colder plugs and TRD 7th kit installed. SC sounds great, never pings (~2500ft elevation where I'm at) I've just changed the oil in the nose. Also have a 2.2 pulley to go with it and a handful of other parts (thermostats, additional bracketry and bolts etc)
    • R150F 5-speed swapped at ~105k miles. Commissioned by previous owner and done by http://sdtruckshop.com/. I helped gather many OEM parts for this swap for the PO. It is a well-done swap and is factory for all intents and purposes (uses correct 2003 manual trans ECM). 90k on trans.
    • Tacoma manual hubs swapped in at ~95k miles. Used all OEM hubs, bearings, seals, CV joints etc. (ADD side-tube still intact and functional)
    • OEM 4.30 gears swapped in from a 3G 4Runner. (still e-lock rear)
    • E-locker "gray wire mod"
    • 255/85-16 BFG KM2 Mud. Set of 5 plus an additional worn spare. All on Tundra spare 16" steelies. About 2500 miles on them
    • New Old Man Emu shocks front and rear with SPC front upper arms and OME front coils and dakar rear leaf pack
    • ARB front bullbar
    • All-Pro apex kick-out step sliders
    • custom front fender bush bars tied to sliders and bullbar
    • Safari Snorkel
    • CBI Offroad Outback bumper with full swing-out with tire mount, hi-lift mount, single can carrier, and drop-down camp table.
    • Rear tailgate inner sheet panel/stiffener (not sure what brand or whatever). Tailgate is very sturdy to stand on
    • Full inner frame boxing from the gas tank all the way back.
    • SPOD installed by P.O. --ready to use for whatever you wish.
    • Pioneer AVH-2300NEX installed by P.O.
    • 3G SR5 4Runner front seats with adjustable bottom cushion and adjustable lumbar support
    • LED headlights installed by P.O.
    • BAMF rear brake bracket
    Maint Items done:
    • Toyota service campaign - frame rust resistant spray - done 2010. Frame is still super solid with very little rust, and even more solid with the additional frame boxing in the rear.
    • Steering rack bushings 8/21/16
    • sway bar bushings 8/21/16
    • sway bar end links 3/24/17
    • OEM LBJs 2/16/17 at 100k miles
    • OEM LCA bushings done 2/16/17 at 100k miles
    • new OEM air filter 12/20/20
    • new rear brake shoes 1/25/20
    • new OEM throttle body 1/5/21
    • New CV boots 3/21/21
    • New SPC UBJs 3/21/21
    • Replaced rear main seal and seat 9/17/21
    • New LCE HD flywheel and dual comp clutch kit 9/17/21
    Additional info:
    • Installed a *brand New* OEM ETCS-i complete throttle body at 155k. Truck runs like a champ now (the old one suffered the infamous 03-04 APPS sensor death - read about here: and if you want)
    • Currently titled and registered in Utah since December 2020. Truck was previously titled, smog'd, and reg'd in Cali for the past 3 years before that without issue.
    Other and Issues
    • P.O. tired several different configurations of roof tent bed bars and up to full rear camper builds, leading to ~30 or so different mounting holes drilled into the bed and top of bed rail. Nothing some liquid steel and bedliner couldn't fix right up.
    • Power steering pump or a hose is leaking.
    Update pic as of 11/06/2021. Few more on this post. Lots more pics in the following posts below from March 2021 as well.
  2. Jan 25, 2021 at 5:53 PM
    04TrDtAcO4x4
    04TrDtAcO4x4 Well-Known Member
    2003 Tacoma
    Sure wished you were close by!
  3. Jan 29, 2021 at 11:46 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Bump for Southern Utah Power!
    digitalferg[OP] likes this.
  4. Feb 11, 2021 at 2:06 PM
    digitalferg
    Southern Utah
    Pics
    20210211_123348.jpg 20210211_123342.jpg 20210211_123337.jpg 20210211_123246.jpg 20210211_123232.jpg
    Neelboi likes this.
  5. Feb 11, 2021 at 2:09 PM
    digitalferg
    Southern Utah
    More pics
    20210211_123225.jpg 20210211_123236.jpg 20210211_123204.jpg 20210211_123156.jpg 20210211_123147.jpg
  6. Feb 11, 2021 at 2:12 PM
    digitalferg
    Southern Utah
    Some more
    20210211_123150.jpg 20210211_123418.jpg 20210211_123212.jpg 20210211_123215.jpg 20210211_123217.jpg
  7. Feb 11, 2021 at 2:46 PM
    digitalferg
    Southern Utah
    And more
    20210211_123354.jpg 20210211_123357.jpg 20210211_123404.jpg 20210211_123715.jpg 20210211_123724.jpg
  8. Feb 11, 2021 at 2:50 PM
    digitalferg
    Southern Utah
    Aaaaaand more
    20210211_123728.jpg 20210211_123729.jpg 20210211_123907.jpg 20210211_123928.jpg 20210211_123935.jpg
    unstpible likes this.
  9. Feb 11, 2021 at 2:50 PM
    digitalferg
    Southern Utah
    And more
    20210211_124100.jpg 20210211_124111.jpg 20210211_124120.jpg 20210211_124049.jpg 20210211_124054.jpg
  10. Feb 11, 2021 at 2:54 PM
    digitalferg
    Southern Utah
    More more
    20210211_124130.jpg 20210211_124143.jpg 20210211_123853.jpg 20210211_123842.jpg 20210211_123837.jpg
  11. Feb 11, 2021 at 3:11 PM
    digitalferg
    Southern Utah
    Still more
    20210211_123830.jpg 20210211_123821.jpg 20210211_123814.jpg 20210211_123806.jpg
  12. Feb 11, 2021 at 3:14 PM
    digitalferg
    Southern Utah
    More still
    20210211_123754.jpg 20210211_123748.jpg 20210211_123703.jpg 20210211_123658.jpg 20210211_123653.jpg
  13. Feb 11, 2021 at 3:16 PM
    digitalferg
    Southern Utah
    And some more
    20210211_123618.jpg 20210211_123613.jpg 20210211_123609.jpg 20210211_123429.jpg
  14. Feb 11, 2021 at 3:18 PM
    digitalferg
    Southern Utah
    See what i mean about being filthy? Dirt and muck caked on everything.
    If there's something I missed getting a pic and you want to see it, lemme know.
    Or if you need closer/ better of something.
  15. Feb 11, 2021 at 4:37 PM
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    Looking for more pics...all four sides, all four seats, underneath, engine bay, etc
  16. Feb 11, 2021 at 5:43 PM
    digitalferg
    Southern Utah
    More than all of what I just posted right before you?
  17. Feb 12, 2021 at 11:25 AM
    archerm3
    Nebraska
    hmm. yeah. lol. I only had like 1 or two pics from each post of yours, my computer didn't download them or something. Now I see the multitude thanks!
    I was smh with the statement "muddy see what I mean" and I was like...i don't see any mud in the 3 pics that were showing. lol.
  18. Mar 21, 2021 at 10:17 PM
    digitalferg
    Southern Utah
    Been driving this truck around town every few days. This thing really is a blast to drive. I've tweaked a few things on it but still need to get to the more pressing items. One last bump here before I start putting effort into it.
    And with Spring around the corner, never know, I may just decide to keep it so I can get some good wheelin and campin in over the next few months.
  19. Mar 30, 2021 at 3:01 PM
    Laloplus4
    Laloplus4 Tacoattack
    Jose
    BAY AREA!
    2017 white tacoma trd off road 2004 tacoma king cab short bed supercharged
    Will u sell the rear bumper its self ?
  20. Apr 10, 2021 at 7:47 PM
    digitalferg
    Southern Utah
    Been working away on this thing some more. I have new CV boots done. Have all new old man emu suspension in. New SPC upper ball joints. And brand new 255 KM2 muds. It already feels like a completely different truck.
    Jiveydude likes this.
Thread Status:
