2003 Tacoma Double Cab rear brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcole999, Mar 14, 2011.
  1. Mar 14, 2011 at 6:21 PM
    mcole999
    mcole999 [OP] New Member
    Need guidance.... Need to replace rear brake shoes on a 2003 Tacoma Double Cab. Auto Parts has $15 and $24 options, dealer $94. Difference in the parts store shoe is missing the adjustment arm, the dealer's has the pivot but requires moving the adjustment arm over to the new shoes. The price difference seems ridiculous. What is everyone doing for replacement brake shoes?
  2. Mar 14, 2011 at 7:12 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    i just got the pads from napa, then got the new spring kit and i think it was like $40 for both together.
  3. Mar 15, 2011 at 8:44 AM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    in most cases you can just get the shoes and clean all the other parts, spraying them down with brake clean works good.
    Just make sure they are adjusted properly so you have close to even use of front/rear brakes
