2003 Tacoma frame rust repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by BossFan, Dec 24, 2020.
  1. Jan 16, 2021 at 3:51 PM
    #181
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’d hope so, it’s brand new! :rofl:
    I make bad financial decisions
    ontarioyota likes this.
  2. Jan 17, 2021 at 12:56 PM
    #182
    BossFan
    BossFan [OP] Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Made a patch panel and spent the morning trial fitting it. Going to do a little practice welding on 22 gauge metal before trying to tack any of this.
    ontarioyota and Empty_Lord like this.
  3. Jan 17, 2021 at 4:30 PM
    #183
    BossFan
    Frank
    NJ
    So my first attempt at welding thin gauge metal is done. It’s not show worthy in the least, but at least it’s secure. I still have to grind down some of the welds but had some questions.
    I read that when welding the thin stuff, you should just tack weld in a spot and then move to another, as opposed to trying to run a single bead. I think it is because the heat could warp the metal if you did one long bead. Anyway, that’s the method I used (and I still did blow through in two places). My question is, should I go back and tack every spot or if it’s nice and tight, can I just run some bead sealer all along the edge and call it a day? And if so, do I do that before I prime it or after? I still have to make two little caps to cover the open corrugated ‘hump’ on each end. Not sure if I am explaining that right.
  4. Jan 19, 2021 at 5:25 PM
    #184
    BossFan
    Frank
    NJ
    I made my caps, sealed everything up with sram sealer and then used a rattle can to paint the patch. I also touched up some of the bare spots on the bed that were caused by the liner. It doesn’t look as good Onakat’s work, but she is probably much better at welding and painting than I am. :). Starting to look like a truck again.
  5. Jan 20, 2021 at 2:21 PM
    #185
    BossFan
    Frank
    NJ
    Finished everything today. Last thing to do is FluidFilm her. As per BDL’s advice, I bought a spray gun and a gallon of FluidFilm. What psi should I set the regular at?
    Here she is. All done. I’m not going to put the plastic liner back in. Maybe I should go with one of those spray-on bedliners?
  6. Jan 20, 2021 at 2:22 PM
    #186
    BossFan
    Frank
    NJ
    My Low-Range Off-road gas skid plate arrived yesterday, along with my e-locker corner. I am trying to decide if I should paint them or have them powdercoated.
    Black DOG Lila likes this.
  7. Jan 20, 2021 at 3:26 PM
    #187
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    @BossFan I ran 80 psi with gun only but cranked it up to 100 psi with the wand extension. I heated the gallon of Fluid Film in a pot of water on the stove to get it to pour into gun and flow when sprayed.
    Good work Frank
    :hattip::hattip::hattip:
    :101010:
    :oldglory:
  8. Jan 21, 2021 at 8:04 AM
    #188
    Black DOG Lila
    Virginia
    Hey @BossFan
    I hope you're going to spray Coroseal inside the frame box sections and allow plenty of cure time before Fluid Film.
    TRDSport10 likes this.
  9. Jan 21, 2021 at 10:31 AM
    #189
    BossFan
    Frank
    NJ
    Oh shoot. I completely forgot about this. I will do this first. How long would you let the Corroseal cure before spraying FF?
  10. Jan 21, 2021 at 10:37 AM
    #190
    Black DOG Lila
    Virginia
    I gave it 2 weeks to cure before Fluid Film inside frame. But I really soaked it good.and it was running out of the drain holes.
    You can still do the outside while inside cures fully.
  11. Jan 22, 2021 at 12:35 PM
    #191
    BossFan
    Frank
    NJ
    Ok cool. That’s what I did. I’ll come back to it next weekend to FF inside.
    I appreciate all the help I got from TW members on this project!
    On an unrelated question, I am currently running 17” Steelers (I think they are from an FJ Cruiser). Since my original 16” spare had a lot of rust on wheel and the tire was still the original spare from 2003, I decided to get a matching spare. When I went to use the spare-tire lift, it was clear that the hole in the center of the wheel is much bigger and the metal brace that slips in just slipped out. Any recommendations? Should I bolt some flat stock to the spare to make the hole narrower? Could I get the piece used on the FJ (if they even use a similar system)?
  12. Jan 22, 2021 at 12:36 PM
    #192
    BossFan
    Frank
    NJ
    Here’s a photo of the new spare compared to original. You can see how the FJ wheel is not a perfect circle.
  13. Feb 15, 2021 at 6:48 AM
    #193
    18 wheeler
    18 wheeler Member
    2003 Tacoma PreRunner 2WD
    let dry Coroseal for a day. Put metal brash on grinder and clean that rim before applying coroseal. All lose part of rust must be removed before applying coroseal.
  14. Mar 21, 2022 at 2:32 PM
    #194
    HighPlainsTaco
    HighPlainsTaco I am haunted by waters…
    Ethan
    Comancheria
    2002 3.4L 4WD TRD
    I know this thread is a year old but I have a question regarding my spare tire cross member. I recently bought an ‘02 4wd. The frame is solid everywhere and passes the hammer test with flying colors. However, the one trouble area is the last foot or so of the frame and cross member that have some cancerous rust beginning. I removed the bumper, which was also rusted inside, and am working on replacing the cross member with the one on my prerunner. I have two bolts that are completely seized on one side and rounded when I tried using a 12 point wrench on them. I’m planning on cutting them out and may just cut the member in half to get it out.
    My question is how structural is the cross member? Is it something that can be left off for awhile since the frame is laterally braced by the receiver hitch assembly?437422DC-640E-4873-A251-447E99DF2437.jpg53C146A4-6567-460D-8B45-9EF8983E31BC.jpg5553309B-EF9B-459F-86CE-C9150408D48E.jpg4DC4220D-92E2-45A6-AC82-D6ABAC673DBF.jpg983A6210-51A1-4867-9144-36BF197450B9.jpg
  15. Mar 21, 2022 at 2:36 PM
    #195
    HighPlainsTaco
    Ethan
    Comancheria
    2002 3.4L 4WD TRD
  16. Mar 2, 2024 at 1:02 PM
    #196
    BossFan
    Frank
    NJ
    I forgot I started this thread about 3 yr ago. Last winter I did the whole automatic to 5-speed conversion. This winter, I revisited the frame rust. Again. I was starting to see some weak areas above the rear wheels. So weak that I could poke holes in the side with a screwdriver. I broke out the de-scaler to clean everything up. The our cone was r pretty. I was going to go the Safe-T-Cap route, but then I saw a guy on YouTube (PostRT) who had basically tge same damage, and what he did was cut out the bad, sections, weld in reinforcements and the. Box in the whole rear part of the frame. That inspired me to do the same. I’ll post a bunch of photos later, but right now I have a shock extension question. Before I decided to go the boxed-frame route, I had already purchased the Safe-T-Cap replaces upper shock mounts. Both of mine were shot. In trial fitting the driver side today, I noticed that I would have to compress the rear about an inch to get the shock on the upper mount at full extension, which means as soon as I did that, wouldn’t the spring just always keep it at full extension? Granted? There is no bed, x-member, gas tank, rear-tire carrier pulling down on the springs now, but is it normal for the frame to be sitting so high above the shock? Should I have longer shocks? This photo was taken with me sitting on the frame and I weigh about 200.
  17. Mar 2, 2024 at 4:34 PM
    #197
    BossFan
    Frank
    NJ
    What started this investigation was that I was that everything I drive the truck, I would hear this clunk behind me. I thought it might be a carrier bearing, but I had just replaced that when I did the 5MT swap. It turned out that the rear passenger body mount had rotted through. I put truck in lift and then found out that where the front of the gas tank mounts also was rotted away. That started the whole process.
    ztwatson likes this.
  18. Mar 2, 2024 at 4:40 PM
    #198
    BossFan
    Frank
    NJ
    I then removed the bed to uncover more problems.
    72151231026__C78BC4DD-41DB-4872-A8EE-FCFFEB9B4224.jpg IMG_3789.jpg IMG_3790.jpg IMG_3844.jpg IMG_4048.jpg
  19. Mar 2, 2024 at 4:44 PM
    #199
    BossFan
    Frank
    NJ
    Then the surgery began
  20. Mar 2, 2024 at 4:48 PM
    #200
    BossFan
    Frank
    NJ
    Some shots of the reinforcement plates:IMG_3906.jpg IMG_3957.jpg IMG_3964.jpg IMG_3969.jpg IMG_3970.jpg
    ztwatson and Northern Taco like this.
