2003 Tacoma frame rust repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by BossFan, Dec 24, 2020.
  1. Dec 26, 2020 at 8:14 PM
    #61
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Is it leaking from rust through?
    MIG it?
    Also had the bright idea to put lag eyebolts in ceiling/floor joists above rope hooks in bed to rope the bed from above and lower the truck rather than lifting the bed.
    Amirite?
  2. Dec 26, 2020 at 8:30 PM
    #62
    Black DOG Lila
    Virginia
    @BossFan
    I assume you can weld better than that Pumpkin chopping Bonehead.IMG_20160918_104322.jpg
    All that for a few pin holes?
    Could have pulled the third member and welded Pumpkin from front
    My $0.02
    2002Tacoma4x4 and JudoJohn like this.
  3. Dec 26, 2020 at 8:46 PM
    #63
    Black DOG Lila
    Virginia
    Amazon Undercoating gun I bought was $29. Looks the same as pic.
    Needle gun is used to remove paint and rust. Small one from Amazon $19
  4. Dec 27, 2020 at 3:07 AM
    #64
    BossFan
    BossFan [OP] Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    My diff cover isn’t leaking. I just thought that when I hit it with a wire brush, it might poke through.
    I’m no expert welder by any means, but I have a Millermatic 211 which is much more powerful than the flux-core welder that that TW member used.
    Funny you mention the lag bolts. I thought about running to Harbor Freight and getting one of their I-beam hoists. I have a steel I-beam that spans my garage ceiling.
  5. Dec 27, 2020 at 3:11 AM
    #65
    BossFan
    Frank
    NJ
    I didn’t see one for $19, but I did find this needle descaler for $38. I wonder if HF has any of these?
  6. Dec 27, 2020 at 4:34 AM
    #66
    BossFan
    Frank
    NJ
    Of course they do. They actually have teo different sizes. The smaller one is $30 and seems to get good reviews. On my way to HF this morning.
    Black DOG Lila likes this.
  7. Dec 27, 2020 at 8:14 AM
    #67
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Yeah, throw the old one out as it must be completely rusted. Then you have two choices: cancel the LSPV entirely or put a new one
    If you want to cancel it, it is pretty simple. Upper line coming from the front of the truck is the IN while the lower line is a return line that sends excess fluid and pressure back to the front. Facing the differential is the OUT.
    Connect the line for the IN to the rubber flex line the OUT connects to (it then goes to a splitter on the diff that sends the fluid to both wheels). Plug or remove the return line as it is no longer needed (it comes from a splitter located inside the driver's side wheel well)
    If you want to replace, you have two choices as well:
    Put a new one. OEM is pricey $$$$ but aftermarket tacoma LSPVs are now available on ebay!
    Do the same as you would cancel but put a manually adjustable proportional valve by the master cylinder on the line that goes to the rear brakes
    #67
  8. Dec 27, 2020 at 9:26 AM
    #68
    BossFan
    Frank
    NJ
    So my trip to HarborFreight this morning yielded a needle gun, am I-beam trolley, a hoist, and some ratchet straps.
  9. Dec 27, 2020 at 9:31 AM
    #69
    BossFan
    Frank
    NJ
    I also removed the factory bedliner. It wasn’t as bad as I thought. There is one bad spot where some of the mulch I picked up last spring got under the bedliner and there is a hole.
    you guys will have to walk me through on how I should patch that after I finish with the frame/crossmember. Rest of the bed looks good (I think). The first pic shows the mulch.
  10. Dec 27, 2020 at 11:59 AM
    #70
    BossFan
    Frank
    NJ
    So the I-beam trolley I bought is too small. The I-beam in my garage is 7” wide and this only goes up to 5 1/2 or something like that. I decided to use my lift. I raised the lift so it would be higher than the bed, then I backed truck unde it. Next, I used 4 ratchet straps to go to the gold down in ea. corner. I almost forgot about gas cap but realized it as I was lifting bed. I was able to maneuver filler mech around fender, and it was free. I rolled truck out and brought in a little landscape trailer. Lowered bed down into trailer (supported by crossbars of 2x4 and 2x6).
  11. Dec 27, 2020 at 12:03 PM
    #71
    BossFan
    Frank
    NJ
    I just lightly started brushing away at some of the rust. Going to grab lunch and start with the needle gun. I’ve never used one of these before, are there any tips/tricks I should be aware of?
    Looks like the spare tire crossmember might be salvageable, but the bars that go across the tire look pretty rough.
    2002Tacoma4x4 and Black DOG Lila like this.
  12. Dec 27, 2020 at 12:05 PM
    #72
    Black DOG Lila
    Virginia
    Good work Frank :thumbsup:
    This write up will help many people in the future.
    Thanks for sharing
    MCJohnston likes this.
  13. Dec 27, 2020 at 12:12 PM
    #73
    Black DOG Lila
    Virginia
    @BossFan
    Coroseal works best on rusty metal so no need to needle gun to bare steel.
    Just knock off the loose rust but leave the surface rust and iron oxide flash which gets converted to Magnetite which is an inert iron oxide.
  14. Dec 27, 2020 at 1:12 PM
    #74
    BossFan
    Frank
    NJ
    Ok. Thanks. I’m hoping the coroseal gets delivered tomorrow. A duet I needle brush it, do I need to wash it down with anything before applying the coroseal?
    Also, what do you make of this passenger shock mount. Not good, right?
  15. Dec 27, 2020 at 2:02 PM
    #75
    Black DOG Lila
    Virginia
    I foam gunned frame with Simple green and pressure washed.
    You don't want oil/grease contamination.
    Crusty shock mount is your call.
    Salty sand gets trapped In that area of frame from hole in backside of mount.
    Safe-T-Cap makes replacement shock mount or use a bolt and 11ga. flat stock steel.
    2002Tacoma4x4 likes this.
  16. Dec 27, 2020 at 4:47 PM
    #76
    BossFan
    Frank
    NJ
    Ok. Thanks. I got the rear crossmember all cleaned up. I also loosened most of the bolts. Still need to unbolt it but wanted to hold off on that, especially since the gas tank crossmember is so rotten. Lol. Do you think I should replace the spare tire straps? It’s only $75.
    Also, the lines coming out of the LSPV. The flare nuts on the ends are toast. Do I just replace the lines or can I cut the ends and re-flare them?
    And what about fuel tank/hoses/charcoal canister? Someone recommended replacing the seals. Anything else? I think the tank is ok but posted a picture below (along with charcoal canister). I think I sometimes get that P040 error code.
  17. Dec 27, 2020 at 5:14 PM
    #77
    Black DOG Lila
    Virginia
    I would spend $75 on spare straps.
    Pull the fuelp pump hatch and replace gasket.
    Clean, inspect EVAP cannister and hoses. The corrugated EVAP hose is expensive and discontinued, be careful.
    EVAP hoses can be replaced with fuel line.
    Brake lines reflair if you already have the tool. Cheap flare tool don't work well on steel lines and the good hydraulic flare tool costs more than new brake lines. Looks like the spare hoist is new. Clean, paint, grease it.
  18. Dec 27, 2020 at 6:28 PM
    #78
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    If you go the route of replacing the gaskets and hoses, here are the ones I had to order:
  19. Dec 27, 2020 at 6:31 PM
    #79
    BossFan
    Frank
    NJ
    Thanks!!
  20. Dec 27, 2020 at 7:57 PM
    #80
    BossFan
    Frank
    NJ
    Ordered all the parts (LSPV, gaskets, fuel tank straps). I looked into the Safe-T-Cap but will also consider the suggestion of making my own replacement using a bolt and some 11 ga flat stock.
    I think temp will be in the 40s this week in northern NJ so am hoping to do the Simple Green/pressure wash combo before applying the corroseal. Fingers crossed.
