2004 frame replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by HAS 4X4, May 13, 2018.
  1. May 13, 2018 at 8:29 PM
    HAS 4X4
    HAS 4X4 [OP] Member
    Hector
    2004 Tacoma access cab
    Nothing
    Hey guys lm new on this web site so , does anyone knows what to do in order to get the frame
    replaced on my 2004 toyota tacoma ? thanks for the help
  2. May 13, 2018 at 8:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You have to call your local dealership and have them do the inspection, your an 04 so you still have time
  3. May 14, 2018 at 2:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This is a 15 year extended warranty not a recall.
    As long as the truck was inspected and undercoated by Toyota .
    The truck needed to be sold in the covered Winter weather states.
    The frame needs to meet the failure criterion you can`t just say I want a new frame
  4. May 14, 2018 at 5:58 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    This bit is not correct. The truck is covered no matter where it was sold. There is an inspection and spraying requirement for trucks that "lived" in one of the 20 cold weather states. How Toyota determines if a truck meets that requirement is unclear.
  5. May 14, 2018 at 6:21 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    First things first. Call a dealership with your VIN number and they should be able to tell you if it's covered. Some dealerships aren't as adept as others. If you are not the original owner then it's up in the air.
    www.toyota.com/owners and sign up. It will have maintenance history if recorded.
  6. May 14, 2018 at 6:28 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    As stated above, the biggest hurdle is whether the frame was inspected and treated by Toyota as part of the enhanced maintenance, this would have been done in the 2010-2012 timeframe. If not inspected and treated, you are SOL (sh** out of luck). Obviously, it must then fail the inspection. 10mm perforation is the standard, I believe.
  7. May 14, 2018 at 6:45 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You can also check www.toyota.com Click "Owners" on the drop down. Enter your VIN to check all previous maintenance done at a Toyota dealer on your truck.
  8. May 16, 2018 at 5:58 AM
    ctjones
    ctjones Well-Known Member
    Bay Area
    2001 Tacoma XtraCab SR5 TRD
    Stock sr5, frame swapped, sick stickers
    I bought a nice frame from a guy in southern GA. he parts out Tacomas for a living pretty much. he also delivers! let me know if you want me to find his info
  9. May 16, 2018 at 10:15 AM
    WVTaco12
    WVTaco12 Well-Known Member
    Cody
    West Virginia
    2013 TX Baja
    Check into it sooner rather than later. Those warranty periods sneak up on you faster than you know it.
  10. May 16, 2018 at 12:54 PM
    HAS 4X4
    HAS 4X4 [OP] Member
    Hector
    Nothing
    Thanks everybody for the advices , l appreciate it .
