2004 frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Jun 15, 2019.
  1. Jun 15, 2019 at 5:49 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello I went to the beach today in my truck I parked away should I still wash my frame ?
    Taco critter likes this.
  2. Jun 15, 2019 at 6:01 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    yes.
  3. Jun 15, 2019 at 6:29 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Yup
  4. Jun 15, 2019 at 6:36 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Leave you frame at home next time.
  5. Jun 15, 2019 at 6:41 PM
    eon_blue
    Azusa, CA
    Just go to one of those self service car washes, put a few bucks in and use the high powered hose they have to spray the frame and underside real good. Try not to blast any of your o2 sensors if they're exposed though.
  6. Jun 15, 2019 at 6:41 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Off limits. Go in your buddies Jeep.
    Prayn4surf and Taco critter like this.
  7. Jun 15, 2019 at 8:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  8. Jun 15, 2019 at 8:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did the truck actually get wet with sea water?
    If no, then you have nothing to worry about.
    GQ7227 likes this.
  9. Jun 15, 2019 at 8:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Ocean spray is a cruel mistress.
    Reh5108 likes this.
  10. Jun 15, 2019 at 8:48 PM
    koditten
    Kirk
    Central Michigan
    Like I said, did it get wet?
    Spending time in Key West I checked out every 1st Gen I come across. I noted zero frame rust. Every vehicle in key West is in sight of the ocean.
    Ask me about sun damaged paint. the sun beats the shit out the paints bad.
    GQ7227 and Wyoming09 like this.
  11. Jun 15, 2019 at 8:50 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I actually drove on the surf in Pismo and my truck faced the ocean the entire night, so I washed the hell out of the frame when I got home.
    Better safe that sorry I guess. Doesn’t hurt to wash the frame.
  12. Jun 15, 2019 at 9:04 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    The sun is making my trucks paint faded especially since it red lol and no it has never been in the water it just been parked by it
    koditten[QUOTED] likes this.
  13. Mar 7, 2020 at 8:49 PM
    Tacoman589
    Tacoman589 Well-Known Member
    2020 Army Green TRD PRO
    GQ7227 likes this.
  14. Mar 7, 2020 at 8:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    No idea. I don’t have to worry about salt in California haha
  15. Mar 8, 2020 at 1:21 AM
    koditten
    Kirk
    Central Michigan
    Do you have a pressure washer to run it? Notice there is 4 nozzles. Each nozzle will only put out 1000 psi because you divide your output by 4. 1000 psi out of a pressure washer is pretty anemic.
    Cleaning units are defined by multiplying volume by pressure. Pressure washers do not put out much volume, but do put out lots of pressure.
    You can find out your cleaning units for just a plain lawn sprinkler using this formula. I bet you will find out that the calculations are very similar.
    With that above ramblings, my opinion is you can do the same amount or cleaning using a lawn sprinkler placed under the truck. In addition, you don't have to constantly move the pressure washer device around.
    The lawn sprinkler only needs to be moved every 5-10 minutes to make sure the entire frame is washed.
    I like that I can walk away from the truck and get some other things done while the frame gets a good washing down.
    GQ7227 likes this.
  16. Mar 8, 2020 at 7:02 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what are your thoughts on using the sprinkler underneath to remove any old/aged/brittle rubbery undercoatings before spraying new undercoating?
  17. Mar 8, 2020 at 7:05 AM
    koditten
    Kirk
    Central Michigan
    Most likely you will be disappointed.
    Nothing beats going after it with an air powered needle scaler. It's quite amazing how well that tool works!
    Black DOG Lila and GQ7227 like this.
  18. Mar 8, 2020 at 7:11 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it would be too much area to remove it all with that tool underneath on my shoulder with one free hand, its sprayed all underneath the cab and the bed
    i'm just looking to remove any loose pieces (which honestly i did NOT notice anything loose checking underneath the last time before spraying a FF type coating to darken it up)
    trying this before i rubbercoat soundproof spray it again with maybe thicker stuff and make my truck as quiet as a mouse on the road :stirthepot:
    i am assuming this new spray coating will adhere to the 23 year old stuff without flaking/peeling off but not sure yet if all the old stuff must be removed first
  19. Mar 8, 2020 at 7:20 AM
    koditten
    Kirk
    Central Michigan
    If you are not in the salt belt, the rubberized undercoating is ok. Around here, that stuff is taboo. It traps water/salt and promotes premature rust thru. No one around here likes the rubberized undercoating.
    Your on your own if using that stuff.
    GQ7227 likes this.
  20. Mar 8, 2020 at 7:25 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    My truck has been parked by the beach for 15 years, just have a normal car wash schedule and you will be fine. Don't over react.
    koditten likes this.
