2004 OEM or at least OEM like headlight and turn signal assemblies
Discussion in '1st Gen. Tacomas (1995-2004)' started by 53rdcard, May 30, 2015.
  1. May 30, 2015 at 3:53 PM
    53rdcard
    53rdcard [OP] Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    both sides on the front of my 2004 have the areas that bolt them into the truck are either cracked or totally broken, both of the turn signal lights will just pull right out, the headlights mounts are cracked and one is only holding on by one bolt
    Im looking for a drop in replacement not really interested in HID lights or any of that, cause i don't want to spend a ton (sub $200) on this fix but want do want at least OEM level of lighting and longevity
  2. May 30, 2015 at 5:11 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well got a lttle bad news for ya, it aint the headlight that those lights connect to, its the front grille and they have a very weak spot on each end where if you are rough with it they crack easily.
    you need to replace the front grille to fix it.
    that said, its cheap and easy to replace it all if you want to make it look new again, I just did everything on mine
    the side lights are $15 each http://www.ebay.com/itm/291177268609?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    http://www.ebay.com/itm/130927526818?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    the headlights I got both for $66 http://www.ebay.com/itm/151055113002?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    and the turn signals $11 http://www.ebay.com/itm/271257690021?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    http://www.ebay.com/itm/310723330040?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    and I went with the all chrome grille for $120 http://www.newegg.com/Product/Produ...vel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
    but there are the original oem stock chrome and black versions for around $65 http://www.ebay.com/itm/01-04-TOYOTA-TACOMA-PICKUP-CHROME-GRILL-GRILLE-ASSEMBLY-REPLACEMENT-/310972846521?fits=Model:Tacoma&hash=item48676d11b9&vxp=mtr
  3. May 31, 2015 at 1:45 AM
    53rdcard
    Well that is good and bad news, and thank you for all of the very helpful links, i really like the all chrome grill, thinking i am going to go with that this time around.
    Have you had the replacements long enough to tell how they hold up over time? i.e. leaking, fogging, chrome pealing off the grill, things like that?
    Found this one on a ebay search, thinking i might order it, as it looks to have all the parts i need in one package
    http://www.ebay.com/itm/2001-2004-TACOMA-PICKUP-CHROME-GRILLE-PARK-LIGHT-HEADLIGHT-W-BULB-5PCS-/171337282748?fits=Year:2004|Model:Tacoma&hash=item27e47f74bc&vxp=mtr
    or this one as it is all chrome
    http://www.ebay.com/itm/2001-2004-T...2004|Model:Tacoma&hash=item2ed1a54aa4&vxp=mtr
  4. May 31, 2015 at 7:35 AM
    keakar
    karl
    louisiana
    literally just did it all this week, by the way the grille comes with all new snap clips and they are a little tricky to snap in so when you think its in all the way give it a little extra bump until you hear the faint click. DO NOT remove the clips and put them on the truck and then try to snap it on. the reason is its all still new so the snap isn't easy to snap and I broke two of them trying so I put them all back on the grill then did as above. the ones on the bottom went on very easy but the ones on the top were the ones I had to give a little extra "bump" until they snapped onto the truck. the all chrome looks nice and im glad I went with that one to get rid of the black insert.
    as to the lights, everything seamed to be made just as well as oem and they look great and the truck looks brand new now, the only thing is my drivers side needs adjusting or the bulb needs to be reinstalled because its pointing high. I changed them after the headlights were installed so I couldn't see what I was doing very well changing the bulbs.
    that reminds me, dont use the bulbs that come with the headlights, get some good bulbs for the headlights, they come with cheapo weak looking bulbs (one of my high beam filaments was broken) so I upgrade to some new Sylvania extended vision bulbs.
    one word of caution, I broke my grille emblem, so when you pout yours back on snap the bottom clip first then the two top clips get snapped. I did it the other way around and broke off my bottom snap so I had to buy a new emblem. im pretty sure it was the way I was putting it on that broke it but being old brittle plastic was part of the reason as well.
    if yours breaks or you just want a new one I found this the best deal on them: http://www.ebay.com/itm/121669052278?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    there are some advertised on Amazon for as little as $8-$9 but those are Chinese stick on emblems falsely advertised as oem parts. I know because I ordered one and just opened the mail to find its a stick on trunk emblem, plus after ordering the guy pawned my order off to a china supplier without me even knowing it.
  5. May 31, 2015 at 7:54 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
