2004 taco transfer case coipler
Discussion in '1st Gen. Tacomas (1995-2004)' started by L8taco, Jan 10, 2025.
  1. Jan 10, 2025 at 1:07 PM
    L8taco
    L8taco [OP] New Member
    I have a 2004 taco 6cyl auto transmission. It has the J-lock manual transfer shifter (not push button). I busted the 1 7/8” coupler between the transmission and transfer case. Toyota in Hattie’s burg says the part was discontinued at the same time he says he can’t find the part on the drawings. We can all agree he is lying and simply can’t do his job. Can anyone on here help me locate the coupler
    Black97v6MT likes this.
  2. Jan 10, 2025 at 3:41 PM
    02hilux
    Planet: EARTH
    I wouldn’t necessarily say he’s lying as tons of parts are obsolete for a 20+ year old truck.
    Ricardo13x, Wulf and Kwikvette like this.
  3. Jan 10, 2025 at 4:17 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
  4. Jan 10, 2025 at 5:05 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Area51Runner likes this.
  5. Jan 11, 2025 at 6:30 AM
    L8taco
    Well the mis leading is saying you can’t find the part in the drawings so you tell your customer it is discontinued. This part makes the truck functional. Nothing has been found in Toyota literature to say it is discontinued. I have uploaded a pic so it is not confused with the push button transfer case
  6. Jan 11, 2025 at 8:32 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Input or output side? I don't recall that being something that is removable and I've ripped apart the transfer case more times than I care to count. If I recall and looking at your pic, that sure does look like its part of the shaft.
    As mentioned above, check the diagrams for yourself. Use your VIN and then look under powertrain. Everything that is part of the trans and the transfer case is there.
    As for a j-shift transfer case, going to be the same guts. Here is a shortened URL to a 1995 J-shift transfer case on partsouq.
    https://shorturl.at/kixXj
    If you want to post up additional pics (zoomed out a bit more), I can take another look. Need to understand how this piece broke off and from where.
    Cheers.
  7. Jan 11, 2025 at 8:35 AM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I think that coupler is part of the transfer case input shaft. Google pn# 36201-35061, it must of broke off of the shaft so that it looks like a coupler. Keep us updated.
    Black97v6MT and Area51Runner like this.
  8. Jan 11, 2025 at 9:17 AM
    Area51Runner
    That is what I'm thinking as well. How it broke... :notsure: If it was from sheer force, I shudder to think of what else is happening inside that transfer case.
    :nuclear:
  9. Jan 11, 2025 at 9:25 AM
    homegrown_xt
    Sonoma County
    Maybe a piece of gear or something broke off and got wedged between the gears, so something had to give? Or really worn out trans/transfer case mount and engine mounts caused enough flex to break it off but the case should show signs of cracking. Weird...
  10. Jan 13, 2025 at 11:52 AM
    L8taco
    It is not broken. It is made that way.
  11. Jan 13, 2025 at 12:31 PM
    homegrown_xt
    Sonoma County
    It's the front piece on that input shaft, that is all one unit.
    Ricardo13x likes this.
  12. Feb 4, 2025 at 10:59 PM
    homegrown_xt
    Sonoma County
    Did you get your truck back on the road, was it that input shaft?
  13. Feb 5, 2025 at 6:22 AM
    02hilux
    Planet: EARTH
    it’s sold new as one unit but the coupler is removable. Keep in mind, coupler is different between 4cyl 26s and 6cyl 23s.
