2004 Tacoma TRD front end part number check and your input
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jolly Onion, Apr 11, 2021.
  1. Apr 11, 2021 at 8:08 PM
    Jolly Onion
    Jolly Onion [OP] Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Hello uncles
    I hope that everyone is staying healthy and happy and away from TV and the chaos associated with it
    Time for a front-end refresh, as the lower ball joints have too much slack
    Just wanted to check with you re:
    1) The part numbers below are correct
    2) Do I have to buy 4 cotter pins or do they come with the parts
    3) what else should I change while at it?
    Car has a new rack & pinion, rubber break lines. Rotors, calipers and Akebono brakes were changed a few years ago and are in great shape
    Front upper ball joints (2) – 43310-39016……..$44.66
    Front lower ball joint – 43330-39556……$122.37
    Front lower ball joint – 43340-39436….$98.87
    outer tie rod - 45047-39175………….. $48.08
    outer tie rod - 45046-39295…….……. $48.08
    boots (2) - 45535-35030……………………….$25.67
    inner boot clamp (2) - 90460-62006……. $6
    outer boot clamp (2) - 90467-33005……. $4.09
    Thank you
    Alex
    An3 likes this.
  2. Apr 12, 2021 at 7:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    parts list looks good. however if you are not replacing the inner tie rods then don't get the boots or clamps. no need to remove them at all or replace unless they are ripped (actually should be new since you replaced your rack)
  3. Apr 12, 2021 at 8:14 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thank you frizzman for the suggestion
  4. Apr 12, 2021 at 10:07 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Any idea what the dealer will charge for installing all these parts? My Toyota certified mechanic said $400, which includes a wheel alignment. I think it is a fair price
    Thanks
    Alex
  5. Apr 12, 2021 at 10:49 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    alignment alone is roughly $100 so basically $300 to install everything isn't bad considering labor costs
    maybe someone else will chime in that knows more
    Jolly Onion[OP] likes this.
  6. Apr 12, 2021 at 10:57 AM
    eon_blue
    Azusa, CA
    $400 all in for a dealer to do it sounds fair to me alignment included.
    Around here that would probably be the cost to just install new LBJs at the dealer.
    I think new inner tie rod boots is a good idea, when I replaced mine I didn't get new boots and my old ones got a tear in them not long after. If the boot tears and dirt/water gets in there it will compromise your new inner tie rods as well as the steering rack.
  7. Apr 12, 2021 at 11:05 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thanks Guys going to order the parts. The mechanic is a foreman at a dealer but does work on the side. No conflict of interest either as i do not deal with where he works and did not meet him via the dealer
    FYI gentlemen, I found the best pricing here
    https://www.mcgeorgetoyota.com/
  8. Apr 12, 2021 at 12:01 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Order placed. Price is right and reasonable shipping.
    Part Number Part Name Price Quantity Total
    43310-39016 Upper Ball Joint $42.36 2 $84.72
    43330-39556 Lower Ball Joint $116.09 1 $116.09
    43340-39436 Lower Ball Joint $92.92 1 $92.92
    45047-39175 Outer Tie Rod $45.60 1 $45.60
    45046-39295 Outer Tie Rod $45.60 1 $45.60
    45535-35030 Tie Rod Boot $21.31 2 $42.62
    90460-62006 Clamp Hose $5.84 2 $11.68
    Subtotal: $439.23
    Estimated Shipping to 11375 via Standard Shipping: $24.22
    Total: $463.45
  9. Apr 12, 2021 at 1:05 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    congrats, enjoy the new parts :D
    SkunkMan17 and Jolly Onion[OP] like this.
