2005+ 2.7 I4 gears
Discussion in 'Technical Chat' started by br217398, Jan 15, 2009.
  1. Jan 15, 2009 at 11:30 AM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    not the former question about gear change which ive read, but i am hearing that the 4.56 would be best, however there is a company that has 4.30 gears..... SUggestions?!?!?!?!?!?
    Thanks
    Brandon
  2. Jan 15, 2009 at 12:01 PM
    sonjay
    sonjay Well-Known Member
    What size tire are you planing on running?
  3. Jan 15, 2009 at 4:23 PM
    br217398
    Orlando Florida
    a 265/60/18 at the moment its 255/55/18
  4. Jan 15, 2009 at 4:36 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    you are puttin bigger tires on?
  5. Jan 15, 2009 at 4:46 PM
    br217398
    Orlando Florida
    265/60/18 at the largest up from 215/70/15 thats stock
  6. Jan 15, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think your truck has 3.15's in it now. I think 4.10's would be a good ratio for those tires.
  7. Jan 15, 2009 at 5:14 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    if im not mistaken you have stock 4.10s now, if you go up a 4.30 should do fine. who makes 4.30?
  8. Jan 15, 2009 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if he has the Prerunner, or 4x4. The others come with a 3.15 gear.
  9. Jan 15, 2009 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oops, My bad....they have a 3.58 ratio
  10. Jan 15, 2009 at 5:54 PM
    sonjay
    I would say 4.10's also, I've heard they are hard to find though? 4.34's are more common?
  11. Jan 15, 2009 at 6:23 PM
    br217398
    Orlando Florida
    ugh so confused........ ::::
    2006 Toyota Tacoma Performance
    2,694 cc 2.7 liters in-line 4 front engine with 95 mm bore, 95 mm stroke, 9.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 3RZ-FE
    Unleaded fuel 87
    Fuel economy EPA highway (mpg): 23 and EPA city (mpg): 19
    Multi-point injection fuel system
    21 gallon main unleaded fuel tank
    Power: 119 kW , 159 HP SAE @ 5,200 rpm; 180 ft lb , 361 Nm @ 3,800 rpm
    2006 Toyota Tacoma Handling
    Four-wheel ABS
    4.1:1 axle ratio
    Brake assist system
    Two disc brakes including two ventilated discs
    Electronic brake distribution
    Fullsize steel rim under body spare wheel
    Wishbone front suspension independent with stabilizer bar and coil springs , beam rear suspension rigid with leaf springs
  12. Jan 15, 2009 at 6:23 PM
    br217398
    Orlando Florida
    which figure should i use
  13. Jan 15, 2009 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That info is for the Prerunner, or 4x4. You have the Base 4x2, right? 5 lug wheels? If so, you have 3.58 gears.
  14. Jan 15, 2009 at 6:48 PM
    br217398
    Orlando Florida
  15. Jan 15, 2009 at 6:50 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I'm sure this is unnecessary at this point, especially being that you know there is stock gears in your rear axle, but there is a really easy trick to finding out the rear end gear(or front) if you are unsure of it.
    Block the front wheels, jack the rear end up and place the vehicle in neutral. Mark the drive shaft with a line parallel to the shaft it self so you can count the revolutions of the shaft. Then spin the tires EXACTLY two turns.
    If the drive shaft spins a hair over 4 times its more then likely a 4.10 gear ratio, 4 and 1/3 its probably a 4.30, 5 and 1/3 probably a 5.29 etc...
    Old trick that works every time.
    EDIT: I forgot to add since a fair amount of these truck come with limited slips, you should only turn the rear wheels once with a limited slip. Two full turns with an open diff.
  16. Jan 15, 2009 at 7:12 PM
    br217398
    Orlando Florida
    ^^thanks for the inside info :)
  17. Jan 15, 2009 at 7:19 PM
    br217398
    Orlando Florida
    chris4x4 thanks for the info as well.... nothing like being confused over 3.10, 3.58, 4.10, 4.30 blah blah .... ill learn one of these days...
