2005-2010 Tacoma Wheel Studs
Discussion in 'Wheels & Tires' started by Rider, Oct 27, 2009.
  1. Oct 27, 2009 at 10:27 PM
    Rider
    Rider [OP] New Member
    06 tacoma 2.7l 4wd
    Hello everyone,
    I recently purchased a set of KMC HD RockStar rims for my ride(2006 tacoma 2.7L 4wd), unfortunately they where off a 2002 tundra. The reason why i'm posting this thread is for some help. The wheel studs on my truck is too short. Bolt pattern works but studs only allows 5mm of thread and i know i will need lugs. I need longer studs! Where can i get some for a reasonable price?
    This is info from dorman:
    Type: serrated
    Thread length : 1.5"
    Thread: M12-1.5
    Knurl diameter(thickness): 14.20mm/.559"
    Knurl length: 8mm
  2. Nov 6, 2009 at 7:29 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I went with the advice from this guy's site and they work great!
    http://www.hunt4steve.com/05TacoExtLn.html
    Use the Dorman REAR wheel stud for 2002-03 Matrix, PN # 610-463:
    Type: Serrated Stud
    Thread: M12-1.5
    Knurl Dia: 14.20mm (0.559inch)
    Length: 55mm (2.165inch)
    Shoulder Length: 26.60mm (1.05inch)
    Head Code: n/a
    Brand: Dorman - AutoGrade - Bagged, ~ $3.30 at NAPA
    NOTE: NAPA PN# is different, if you get them from NAPA, use PN# 641-4208
    You'll be able to buy either individually or 10-packs from RockAuto.com. Use their part # search for Dorman 610-463 and they come right up.
    Welcome to TacomaWorld. :)
    G's 05taco likes this.
