2005-2015 Tacoma Front Hidden Recovery Bar by Mobtown Offroad
Discussion in 'Mobtown Offroad' started by Mobtown Offroad, Feb 19, 2015.
  1. Jan 25, 2016 at 7:10 PM
    #281
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  2. Jan 25, 2016 at 7:11 PM
    #282
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Dude, is that with the plate holder? Nice.
  3. Jan 25, 2016 at 7:19 PM
    #283
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    It is. I'll send you yours shortly. Still at powder. The one on my truck was prototype and spray painted.
  4. Jan 25, 2016 at 7:26 PM
    #284
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Winning!
  5. Jan 25, 2016 at 7:41 PM
    #285
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Anything like this for 3rd Gens?
  6. Jan 25, 2016 at 7:45 PM
    #286
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Soon. I have most of it figured out. At least, how it'll bolt up. Issue is the third gens have a lot more empty space behind the bumpers and the valence is skinner and in a different spot. Smartest option is to go low but it'll require bumper cutting.
  7. Jan 25, 2016 at 8:50 PM
    #287
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    Here is my 2014.
  8. Feb 20, 2016 at 3:04 PM
    #288
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Got my Mobtown Offroad Recovery Bar yesterday. Packaged nicely.Very Beefy, nice clean weldsIMG_0156.jpg
    Didn't need these two nut/bolts because... IMG_0163.jpg...Already had the OEM bolt with its captured/welded nut in place IMG_0157.jpg
    Had to use a BFH and considerable manhandling to align the recovery bar bolt holes with 3 Crash Bar studs. Partially stripped the stud. Need to get that fixed later. Also, only two studs on the Recovery Bar per side and two additional un-used holes. The OEM aluminum Crash Bar support has three on each side. @Mobtown Offroad - any chance the third stud was not installed? (Your pdf Instruction sheet also shows 3 studs on each side.) IMG_0160.jpg
    Took truck for a 4-Lo, locked rear diff romp in the mud to test out the Recovery Bar. Worked fine. LOL IMG_0165.jpg
  9. Feb 20, 2016 at 3:11 PM
    #289
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    DrFunker and Mobtown Offroad[OP] like this.
  10. Feb 20, 2016 at 3:14 PM
    #290
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Did you use the grade 8 bolts on the underside slots?
  11. Feb 20, 2016 at 3:27 PM
    #291
    Subway4X4
    Lloyd
    NY/NJ
    No. the OEM bolt with the nut welded on still looked fine. Should I have used the grade 8 bolt you provided?
    Is this the bolt we are talking about?
  12. Feb 20, 2016 at 3:28 PM
    #292
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Well, you don't "have" to. Itll be fine without but sometimes those caps dont work. Hole placement is all over the place.
  13. Feb 20, 2016 at 3:31 PM
    #293
    Subway4X4
    Lloyd
    NY/NJ
    I'll try to change out to your fresh grade 8 bolt tomorrow. Should be easy, since it's exposed underneath.
  14. Feb 20, 2016 at 3:37 PM
    #294
    Subway4X4
    Lloyd
    NY/NJ
    @Mobtown Offroad - did you guys forget the third stud that bolts down each side of the OEM aluminum crash bar? The pic on your instruction pdf shows 3 studs on each side Step 13.)
    Here's mine, with two studs and two spare blank holes:
    TAC1 likes this.
  15. Feb 20, 2016 at 3:38 PM
    #295
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    No. Its an unnecessary cost for us and not needed. Its only holding an aluminum crash bar. Only need one in opposing corners for it to be secure.
  16. Feb 20, 2016 at 3:46 PM
    #296
    Subway4X4
    Lloyd
    NY/NJ
    OK. I agree with this. It doesn't appear to be a structural requirement from what I can see.
  17. Feb 20, 2016 at 3:50 PM
    #297
    Subway4X4
    Lloyd
    NY/NJ
    On the far lower right: Those are awfully low profile skinny tires on classic white rims :thumbsup:
    DrFunker and Tacomatwo[QUOTED] like this.
  18. Feb 20, 2016 at 4:35 PM
    #298
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Haha. That is a better than 40 year old pedal powered Massey-Ferguson. Love the pizza cutters.
  19. Feb 20, 2016 at 5:36 PM
    #299
    Subway4X4
    Lloyd
    NY/NJ
    Hey @JohnNP - Are those 7/8" shackles with a full 1" Pin? Or 3/4" shackles with a 7/8" Pin. Do you mind sharing info on the shackles and the rubber protector thingy too? Brand, where you bought them, etc.
    Thanks!
  20. Feb 21, 2016 at 3:30 PM
    #300
    JohnNP
    Hobe Sound, FL
    The shackles were just the Smittybilt black they were 3/4's as I recall. It was the size that mobtown recommended on their site I remember that for sure. I bought them at my local truck store. The red thingies are from Amazon and here's the link. They come in black/blue/red.
    http://www.amazon.com/gp/aw/d/B00A6...3&pi=SX200_QL40&keywords=daystar+red+isolator
