2005-2015 Tacoma Front Hidden Recovery Bar by Mobtown Offroad
Discussion in 'Mobtown Offroad' started by Mobtown Offroad, Feb 19, 2015.
  1. Mar 1, 2016 at 1:06 PM
    #301
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
  2. Mar 16, 2016 at 9:00 AM
    #302
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Was really wishing I had one of these installed over the weekend. Digging out my factory receiver point was a pain in the ass. I may be hitting you up soon.
    Mobtown Offroad[OP] and DrFunker like this.
  3. Mar 16, 2016 at 2:22 PM
    #303
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Classic.
    zerotimeouts likes this.
  4. Mar 16, 2016 at 7:49 PM
    #304
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Sorry to see you got stuck like this, I too got stuck, exactly like this once and that is how the recovery bar was born. Digging under the front end to fish a strap through with a d ring suuuuuuuuuuuuucked.
  5. May 27, 2016 at 8:12 AM
    #305
    jowybyo
    Joe
    Baltimore, MD
    It's the end of the week and our sale is almost over. Get everything while you can. Use SPRING2016 to get 20% off your order.
  6. Jun 23, 2016 at 10:51 AM
    #306
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I have been reading this thread for the past week. I was first looking at Undercover Hidden Winches which lead me to US Offroads version which I like more because you have to remove the lower valance. I actually like the look of the steel "valance" with the recovery points. It looks tough. But, I don't see the value of adding a winch up front for the offroading that I do. That eventually lead me to this product.
    I have a couple of questions. The one bolt that is missing per side is where the OEM Aluminum bumper bolts too, correct? So this hidden receiver bolts up to the same 3 bolts that are attached to the chassis meaning, correct?
    I just want to make sure since I may get a portable winch and I want to make sure that this item will be properly attached to the chassis.
    Thank you
  7. Jun 23, 2016 at 1:18 PM
    #307
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    That is correct. You remove the factory aluminum crash posts and unbolt the factory aluminum crash bar from the post. Then throw the post in the trash and bolt the factory aluminum crash bar to our recovery bar. Then bolt the recovery bar back over the studs that the factory aluminum crash post use to be bolted to.
    TAC1[QUOTED] likes this.
  8. Jun 23, 2016 at 6:43 PM
    #308
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OK. Thank you
  9. Jun 23, 2016 at 6:45 PM
    #309
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I am interested in this product. According to your website it won't ship for a month. Is that still the case?
  10. Jun 23, 2016 at 8:25 PM
    #310
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Currently, yes
  11. Jul 10, 2016 at 2:28 PM
    #311
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    just got my recovery bar on Saturday. Will probably pull my bumper off and install tomorrow. Any tricks to the install or things I should be aware of?
  12. Jul 10, 2016 at 2:44 PM
    #312
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Not really. Just make note of which clips and screws go where as you remove the front bumper cover so you know where they go when reassembling.
  13. Jul 25, 2016 at 5:58 PM
    #313
    Bigjoe7757
    Bigjoe7757 Well-Known Member
    SE P.A.
    2015 access cab 4x4
    What the weight of this recovery bar, also whats the measurement between the recovery points. I was thinking of one with no receiver is that still possible. I would love to install a 20 inch LED Bar between the recovery points and then an avid bumper guard out front. Thanks for any info
  14. Jul 25, 2016 at 7:52 PM
    #314
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Weight is approx 55 lbs and the measurements between is I believe 24". It was designed to fit a 20" light bar between the recovery points. We stopped offering it without the receiver due to demand but we could do it for you if interested.
  15. Aug 11, 2016 at 8:01 AM
    #315
    jowybyo
    Joe
    Baltimore, MD
    Suddenly our Hidden Hitch Recovery Bars are crazy popular. Let's keep it going.
    Nimble9 likes this.
  16. Mar 20, 2017 at 7:45 AM
    #316
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Just found this unit, definitely need one for winch purposes.
    Question regarding the install, do you have to trim the bumper to get the hitch mount to fit through?
    How close is the back of the hitch to the radiator? Looks like if you caved that a little it would smash all that in.
  17. Mar 20, 2017 at 9:42 AM
    #317
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    yes, there is a bit of trimming on the lower valence to for the Hitch and the recovery points, its all done in the black plastic grille, and you can get a part to replace the grill if you ever go back to stock. and theses tons of clearance behind, this replaces the factory aluminum crash bar assembly, so unless you rear end someone doing 80, your radiator will be fine.
  18. Mar 20, 2017 at 12:36 PM
    #318
    Larueminati
    Western MA.
    ^ Awesome, thanks. I'll be getting one in the near future.
    Didn't realize it replaced the aluminum guard.
  19. Mar 24, 2017 at 8:06 AM
    #319
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Ordered mine this morning. Can't wait for it to get here.
    Mobtown Offroad[OP] likes this.
  20. Mar 24, 2017 at 8:34 AM
    #320
    Phoosa
    Truck
    These things still come with a receiver or is that a special request kind of deal?
    Asking for a friend.
