2005-Current Tacoma Rear Disc Brake Conversion Kit From Trail Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CajunCrawler, Oct 30, 2024.
  1. Oct 30, 2024 at 10:52 AM
    CajunCrawler
    CajunCrawler [OP] Well-Known Member
    Cooper
    2015 Black Tacoma
    JL audio speakers, amp, sub Black method 305 wheels 285/75r16 BFG KM3 Bilstein 6112/5160 JBA uca total chaos diff drop
    They make a rear disc conversion for the 2nd gen and it is half the cost of the S.O.S kit ($1500) and right now it is only $500 the only thing you lose is your e brake. I use it every time I park but its just a habit I usually don't need it. What is the negative if losing my e brake.
  2. Oct 30, 2024 at 10:57 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Living in the world we live in...lets just say it rolled off and killed somebody ,or caused damage to property..Lawyer would be all over that
    Musubi3 likes this.
  3. Oct 30, 2024 at 11:01 AM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    Where I live its flat and most people don't activate them so there fine the brakes would also be stronger as in stop better.
  4. Oct 30, 2024 at 11:03 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Did you already upgrade your front brakes? You will get much more performance out of something out front.
    BabyBilly likes this.
  5. Oct 30, 2024 at 11:08 AM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    I do realize this but they don't have anything for the front brakes. This kit is on a pretty big discount right now and a rear disc conversion has always been on my future mod list.
  6. Oct 30, 2024 at 11:13 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Do you have massive HP or towing that make that upgrade necessary?
    SR-71A likes this.
  7. Oct 30, 2024 at 11:15 AM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    I do tow a good bit and my brakes also just are not the best.
  8. Oct 30, 2024 at 11:31 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Aside from the safety issues, it'll put more strain on your trans if you have an auto.
    I agree with the above that front brakes is a more worthwhile mod than the rear.
    1 Limited Toyota likes this.
  9. Oct 30, 2024 at 11:39 AM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Definitely a awesome deal for someone wanting to do the swap. Though the SOS and TG kits have a few differences which is why there is price difference.
  10. Oct 30, 2024 at 8:04 PM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    I do get this but if there a good bit better than drums I would rather get them than spend 1500 on the best rear brakes when I could do mid travel for that money.
  11. Oct 30, 2024 at 8:19 PM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    Don't you have a 4th gen which has rear disc brakes? I don't know if you know what 2nd gen brakes are like.
  12. Oct 30, 2024 at 8:21 PM
    CajunCrawler
    Cooper
    2015 Black Tacoma
  13. Oct 30, 2024 at 8:22 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    If you only change the rear brakes into dish conversion kit you will be disappointed because it does not make it better only make it look better because to feel it you upgrade the brakes you need to start from front brakes. Trust me I was about to buy SOS kit but still you need to upgrade your MC and Booster brake to feel the rear conversion brakes. My opinion don't buy less then SOS kit, definitely you will need e brake someday.
    After you swap MC and booster plus upgrade your front brake from 4runner you may to hold the rear conversion kit.
  14. Oct 30, 2024 at 8:24 PM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    I am planning to do a bbk soon with a mc
  15. Oct 30, 2024 at 8:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This.
    OP I urge you, go out in a safe straight stretch of road, paved and unpaved. with ABS off, forcibly roll into the brakes.... which wheels lock up first? In both conditions I guarantee the rears lock up first in their stock form. Never understood why people are so hot to do a rear disc conversion. Do upgrades to the front brakes (4 runner larger calipers / rotors conversion if you have 17in rims)
    If you are towing to the point of having braking problems you need trailer brakes. PERIOD. My truck towing/loaded with 4500lbs of trailer n stuff in the bed stops just as good as empty with proper trailer brakes.
    zippsub9 and fatfurious2 like this.
  16. Oct 30, 2024 at 8:41 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I have the SOS setup. I originally had no E-brake but had to get the E brake setup later. State inspection required E-brake. I also have GX460 brakes up front with Tundra booster. I actually have the rear brake conversion which most commenting do not. I also have a solid 700 additional lbs hanging over the rear axle providing additional weight for traction increasing the rear braking performance for 37s.
    Rear Cap, DCLB, coated in bedliner
    Dual swing out high clearance rear with 15 gal of liquid and spare 37
    3x 100w solar panels on top of cap
    Bedslide and 33 gal long range fuel tank.
    fatfurious2 and Operator8 like this.
  17. Oct 31, 2024 at 5:11 AM
    Operator8
    Woodland Park, CO
    SAS INW
    Yeh, I'm at around 6000lbs per the CAT scale (and that was on 37's, I'm on 40's now). And even after the SOS front BBK and Tundra booster, I felt the need to do the rear SOS kit. It's been about 6 months, and I've been impressed with stopping performance since the change.
    zippsub9[QUOTED] likes this.
  18. Oct 31, 2024 at 5:18 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    100% agree with this
    A lot of people on here never drove an old car with shit brakes, and it shows.
  19. Oct 31, 2024 at 6:45 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I say it's your truck. Do what you wanna do with it! Worse things to spend money on than brakes.
    That said, the Trail Gear kit mentions "custom made GM style rotors". Any time I hear that I think of potential parts sourcing issues in the future. The nice thing about the SOS kit is that it uses Toyota consumables which are more easily found everywhere when you need them, not some parts hunt wild goosechase down the road. Plus, you get an e-brake with the SOS kit so definitely the direction I would lean, especially since Black Friday is just around the corner and SOS always seems to do a sale.
    Good luck!
    SR-71A likes this.
  20. Oct 31, 2024 at 7:30 AM
    CajunCrawler
    Cooper
    2015 Black Tacoma
    I forgot about Black Friday bbk next then
    DesertRatliff likes this.
