2005. Misfire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiatt1991, Dec 22, 2010.
  1. Dec 22, 2010 at 10:57 PM
    Hiatt1991
    Hiatt1991 [OP] Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Today I was driving my Tacoma and it started jerking pretty bad. I don't know if it was missing or what but I felt the jerking. Do you know what it could be? I recently changed the spark plugs and found out that the previous owner ruined 2 bolts that hold the part that connects the wire to the plug although it seems to be held in place ok?:confused:
  2. Dec 23, 2010 at 12:31 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Do you have an aftermarket air filter?
  3. Dec 23, 2010 at 1:19 PM
    Hiatt1991
    Hiatt
    After doing a lot of searching, I couldnt find any cracks. One hole is stripped in the engine block and the other hole is fine its just the bolt head came off and I have to way to get it out. I tried an extracter but I got no luck. Also, I was told that a hielcoil would be good for the stripped hole on the block? im not sure
  4. Dec 23, 2010 at 1:20 PM
    Hiatt1991
    Hiatt
    oh and I cleaned the MAF and the airfilter is clean as well. It all started when I changed the plugs and noticed the problem.
  5. Dec 24, 2010 at 6:29 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Are these these for the bolts that hold the coil packs down? If so, they aren't threaded into the block but into the valve covers. I think a helicoil would work just fine, just don't torque 'em down so tight in the future. They don't really need it and it sounds like PO did just that.
  6. Dec 24, 2010 at 11:33 PM
    Hiatt1991
    Hiatt
    Ya I noticed you are right. I realize that I can either get helicoils or new valve covers. A set of valve covers is about 500 but Im not sure about the helicoils or if they are durable. Can anyone vouche for that?
  7. Dec 24, 2010 at 11:38 PM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    Helicoils are just about as durable as regular threads in my opinion. I've used them in some pretty serious motor applications on motorcycles and they held up really well. This is if you do them correctly, that is.
  8. Dec 25, 2010 at 7:43 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Just to add to that.... My company installed helicoils in a cast aluminum housing for line mounted CATV amplifiers. They put the helicoils in because tech's had to get inside them twice a year to adjust the gains of the amps and they had to pull-up the housing really tight for weather seal as well as RFI. Just threading into the aluminum would not have held up under that useage and give 10 years service.
    For this application where the bolt isn't taking any load worth mentioning, helicoils will last far longer than the original aluminum threads. Just be sure to install them carefully: use a bottoming tap and coil of right length.
