2005 or Up Double Cab Tacoma Custom Sub Enclosure With 12" IDQ12v3 Columbus Ohio
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Taco21, Jul 22, 2011.
  1. Jul 22, 2011 at 8:13 AM
    Taco21
    Taco21 [OP] Member
    Tim
    Columbus Ohio
    2010 TRD 4x4
    Stereo
    Asking $450 I Would Rather Not Have To Ship
    Used for less then 1 year & Never Abused This Is A Taco Tunes Custom Box & Sub It Has A Rino Liner Hard Shell Coating On The Outside It Looks Awesome & Is Easy To Install
    I purchased a new truck and can not use this system.
    Sells new for $600 plus shipping this is the Dual 4 Ohm Voice Coil - 2 or 8 Ohm Load
    http://shop.tacotunes.com/Subwoofer-Enclosure-Port-Tuned-12-DCT-TACO-PSUB12-1L.htm
    Research This Sub And You Will See That It Is One Of The Best SQ Sub Woofer That You Can Buy & The Sub Alone Sells For $279 Plus Shipping IDQ12V3.D4 - Image Dynamics 12" IDQ Version 3 Dual 4 Ohm Subwooferhttp://www.amazon.com/IDQ12V3-D4-Image-Dynamics-Version-Subwoofer/dp/B004Z8VATI
    Port Tuned 12" Subwoofer box. Includes an Image Dynamics 12" IDQV3 Subwoofer. Handles 500 watts RMS. This sub will KILL dual 10" or 12" subwoofers in sealed boxes. The box was designed with assistance from ID. It is port tuned at 34Hz and will provide VERY low extension that a smaller sealed box can not deliver.
    It provide awesome sound quality and the low end extension not available in small sealed boxes. We have had MANY people upgrade from dual 10 inch subwoofer setups this setup and state it is much better sound quality and much more low end bass. This is not "boomy" bass. It is very well tuned to provide high end sound quality.
    Currently we do not sell this box unloaded as it is tuned to work with the IDQ subs.
    Custom Designed to hide behind the seats in your Double Cab Taco
    The box is made with ULTRA high quality 3/4 MDF for best sound quality.
    Installaton: To install this unit, you will need to remove the saftey hooks and flatten one bracket Use 3 bolts and selaer to attach the box to the cross brace in your truck. This will keep it from "rattling" when going over bumps and helps stiffen the box. Your seats will go back into place. However you can no longer fold the seats down.
    All plastic behind the seats must be removed.
    For More Information Call 614-592-5222
    (Click Below For More Pics)
  2. Jan 10, 2012 at 2:48 PM
    mcampos0
    mcampos0 Today I Will!!!!
    Mark
    EL Paso
    09 DC Pre
    Mud Flaps Off, Window Tint, Keyless Remote w/ Kill switch n Alarm, Straps for shovel in back, Avh-3100DVD, 3in toytec lift, 285/75/16 Nitto tera Grapplers on stock 16 wheels, Polk Audio MM speakers all around
    I want.. To bad shipping is not a option.
