2005 taco vs. 2007 taco
Discussion in 'Performance and Tuning' started by BIGLuke, Apr 19, 2008.
  1. Apr 19, 2008 at 10:52 AM
    BIGLuke
    BIGLuke [OP] I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    question for all of you i have a 2007 taco but i was reseching online and stumbled across a website that tells you the hp and torque for any car. now for some reason on the 05 the hp is 245 and torque is 282 now on the 07 the hp is 236 and torque is 266 does anyone know what the difference is between the two and is so what can i do to get my 07 up to that "standard"
    all responses greatly apreciated
  2. Apr 19, 2008 at 11:00 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The difference is that the 05 was rated using 93 octane gas and the 07 was rated using 87 octane. The change was required because 87 is a recommended fuel. You can have the 05 performance in the 07 by using the higher octane fuel.
  3. Apr 19, 2008 at 11:12 AM
    toycoma671
    toycoma671 Well-Known Member
    Jacksonville, FL
    2007 Prerunner,Sbed, Indigo Ink,TRD
    Blacked out headlights & tail lights,Eye lids, and stainless steel billet grill, Debadged, 10" RockfordSubs, 6x9 Polk speakers, 6 1/2 speakers, JVC CD Player, Vent Visors, Nerf Bars, 20% Tint front, 15% bk Pop-lock, Tonneau Bed cover, Rockford punch amps, OEM Tacoma Bed mat, Toycoma Sport Brakes
    Wow! is that really true! I mean just on the Gas alone you get all that performance? Come on, I mean if the CAI and Exhaust parts can barely give us HP then shoot why spend all the money on these parts when all we have to do is change GAS! where did you get this info????
  4. Apr 19, 2008 at 11:32 AM
    Roland
    Rhode Island
    An engine has to be designed or tuned to take advantage of higher octane gas. The V6 Tacoma's compression is almost high enough to require premium fuel (If you have the supercharger it IS required) and takes full advantage of the higher octane. When you run regular gas in it the engine compensates for the lower octane fuel to avoid detonation at the cost of less horsepower and torque. If you put premium fuel into the lower compression 2.7L engine (Or any other engine not designed for high octane fuel) you'd just be throwing your money away.
    In effect the premium fuel doesn't give a performance boost it's really more of the regular fuel hobbling the engine in the name of saving a few dollars a tank.
  5. Apr 19, 2008 at 2:53 PM
    BIGLuke
    Luke
    Chicago suburbs IL
    ok so what you are saying is that the 4.0 has high enough compression to require higher octane fuel, and if i was to use higher octane fuel i would be getting 245 hp and 282 torqe. but since am using regular low octane fuel my hp and torque is lower. i mean to be honest with you that kinda seems wack. anyway so there is no difference in the 4.0 in the 05 and the 4.0 in the 07 engine wise or performace wise. all it is, is the gas that is being used.
  6. Apr 19, 2008 at 6:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    from what i understood, it was the way they tested...not sure if it was b/c of the fuel
  7. Apr 19, 2008 at 6:40 PM
    pumo420
    pumo420 Well-Known Member
    florida
    07 Prerunner Sr5 Debadged
    silver star headlights, optima yellow top battery, 2X10 mtx thunder 4500 speakers, kicker kx 400 amp, pioneer headunit, injen air intake, flowmaster dual exhaust, doug thorley long tube headers. waiting to put on urd maf caliberater, urd o2 senser, urd supercharger and 7th injector setup.i Fell
    thats pretty sweet i normally only use 93 octane on my taco. i heard that the difference was due to how horse power was measured. and there is new regulations for it you know.
  8. Aug 26, 2008 at 11:35 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    This isn't because of the fuel.
    SAE testing standards came into place sometime after 2005. Many manufacturer's were not testing to the SAE standard, and when the SAE became the standard for measureing HP and TQ, many manufacturer's numbers went down slightly.
  9. Aug 26, 2008 at 1:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    To add to what Klown said, The "old" way of testing required that all major accesories to be on the engine when getting dyno rated. NOW, Not only do the accesories need to be on the engine, but the engine has to be breathing thru a factory air box, with filter, and full factory exuast. In other words, its tested just as it would be sitting in the truck. There is still no guide line as to what grade of fuel is to be used when testing, but Toyota and Chevy use 87 octain, unless noted in an add, or in the manual. Nissan, Dodge, and Ford have been useing a higher octain fuel to get their numbers. Also, manufactures can have their engines h.p. "Certified". So far, as far as I know, only Chevy and Toyota have done this. Its mostly for "Bragging rights" for what I know. :)
  10. Aug 26, 2008 at 3:43 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    X2 to chris. Thats what I heard too. But the kid at the toyota dealership tried to tell me it was because of the fuel.
    But I'm with Chris...
  11. Aug 26, 2008 at 5:16 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yall got it all wrong.... what you need is a ram jet on the back of that sucker :D
  12. Aug 26, 2008 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    People at dealerships really dont know alot. Toyota has always rated their engines on 87 unless notted, i.e.the Supra.
  13. Aug 26, 2008 at 7:13 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    another simple way the horse power could be different was they dyno'd a 05 manual and an 07 auto... as auto's suck little more power out on dyno
  14. Aug 26, 2008 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Manufatures H.P. ratings are at the crank. Tranny has no affect on it as it is not connected at the time they dyno a motor.
  15. Aug 27, 2008 at 8:21 AM
    anc2514
    anc2514 New Member
    the ONLY state that matters - TEXAS!
    05 Prerunner SR5
    +1
  16. Aug 27, 2008 at 8:38 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Well crap! I have been running 93 octane since day one and from what i read above I didn't need to? Wonder how much money I could have been saving, .......yep, ALOT! Does 93 octane run more clean and keep carbon deposits from building up as bad?
  17. Aug 27, 2008 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It has the same addatives as the 87 as Federally required. It will help performance as the programming of the V6 ECU allows a little more power to be made with higher oct. fuel.
  18. Aug 27, 2008 at 8:59 AM
    Dark Knight
    Jeff
    NC/SC
    Ahh thx Chris. think i'll stick with the 93 as I'm used to the price and who wouldnt like a bit more power.
  19. Aug 27, 2008 at 11:01 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Can any prove with Documents and a Dyno chart about 93 vers 87 in these trucks.
    From my college run by Toyota i was told Octane will not increase horse power allone.
    You need to run the lowest octane you can that will not give you Ping or detination.
    Lower rated fuel burns faster, this is why car wil ping, as the BOOM happen to soon and parts are getting moved at the wrong time.
    Highter Octane fuel burn Slow, I mean really slow. So the pats like vavles have time to seat back in place and get rady for the Booom...
    i am not calling any one out, but Toyota has alwasy used 87 as the base fuel for all cars non turbo and non supra.
    So before we all blow our stack lets see proof of this 93 octane claim.
  20. Oct 23, 2008 at 3:39 PM
    audiophile22
    audiophile22 The Anti Alliance Alliance. BAM!
    Little Rock, Arkansas
    2007 Tacoma
    Pioneer 9600, Alpine Amps, Infinity Speakers, XM, Ipod 5% tint, Rain Guards, Debadged. 3" Toytec Lift, Flowmaster exhaust, more to come...
    cuz u can really tell a difference with that minimal of HP increase... REALLY people? come on.
