2005 Taco will not start just clicks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BobVerde, Nov 10, 2009.
  1. Nov 10, 2009 at 4:54 PM
    BobVerde
    BobVerde [OP] Member
    BOB
    CAMP VERDE, ARIZONA
    2005 TRD 4X4 TACOMA
    Lift kit 3", 10,000 winch, Nerf bars, K&N, Bed cover, 17" Black Pro-Comp Wheels with 32" Tires,
    :confused: Need help Please:( Disconnected the battery and now it just clicks? Does something have to be reset? Did I burn up something, it acts like a dead battery but it shows that its charged? Every thing else works great, I REALLY NEED YOUR HELP GUYS!!!
  2. Nov 10, 2009 at 4:56 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    try jumping it.
  3. Nov 10, 2009 at 4:56 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    could be the starter
  4. Nov 10, 2009 at 4:56 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Did you reconnect the battery? I'm assuming that you did!
    Sounds like a bad connection. Try to wiggle the cables and, if it works, you need to remove the cables, clean the terminals, and then put it back together.
    Cheers.
  5. Nov 10, 2009 at 4:57 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Does it have some kind of aftermarket alarm system?
  6. Nov 10, 2009 at 5:25 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Disconnect the battery again, clean all the connections & terminals. Reconnect & tighten connections.
  7. Nov 10, 2009 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. If it starts, the battery could be weak. If it does the same thing, it could be a starter issue
  8. Nov 11, 2009 at 7:33 AM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    I agree. Get under the truck with a hammer and tap the starter a few times and try it again.
    Edit: you might think thats a little crazy, but try it. It depends on what the problem is, but this will temporaraly fix a starter that won't engage however, you will likely need a new starter.
  9. Nov 11, 2009 at 7:34 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    x3. Clean those battery terminals, reconnect everything, and make sure the terminals are tight. The starter draws a lot of current and needs solid connections.
  10. Nov 11, 2009 at 7:50 AM
    BobVerde
    BOB
    CAMP VERDE, ARIZONA
    2005 TRD 4X4 TACOMA
    You guys are great, I'll start today with your idea's on the fix.
  11. Nov 11, 2009 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How do you know? When was the last time you started your truck?
  12. Nov 11, 2009 at 7:57 AM
    mjp2
    NJ
    I once, many years ago, had a truck that I was able to drive. :p
    It was a common problem on an old Bronco I had back when I lifeguarded. The salt in the air would corrode the hell out of the battery terminals and I'd be left with the clicking issue. Were I smarter I would have covered everything in dielectric grease after they were clean.
  13. Nov 12, 2009 at 12:27 AM
    frozen_taco
    frozen_taco Well-Known Member
    Fairbanks AK
    05 Off rd. trd acc. cab with modddds
    flowmaster 50 series delta flow dual exhaust, grillgraft mesh, BHLM, VIPER 2 way auto start, Alpine 10" type R subwoofer, Custom made sub enclosure in back, aries tube steps, K&N, 20% tint, debadged, 20"X9 panther realm rims, Nitto 420 tires, blacked out tails, visors, PIAA headlights, bug guard,
    I had starter problems a few years ago and had to do that a few times while the new starter was in the mail, pretty embarrassing. It does sound like it could be the problem your having.
