2005 Tacoma 2.7L 4 cylinder Performance upgrades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JiuJitsuBlkBeltTacoma619, Feb 7, 2018.
  1. Feb 15, 2018 at 1:53 PM
    JiuJitsuBlkBeltTacoma619 [OP] #RESPECT
    ZZ
    Chula Vista California (south san diego)
    05 2.7L 4 cylinder access-cab 2WD, 5 lug
    volant cold air intake, all terrain tires, snug top camper shell, thule roof racks, iKamper roof top tent, tow package, 3 gallon shower, auxiliary battery, power inverter, roof rack mounted led lights, fog lamps, exterior LED bulb kit.
    Here’s a couple pictures of my 05 Tacoma. I have the heavy duty rancho shocks to help
    compensate for the extra weight of the camper shell and roof top tent. I think the regear 4:10 and positraction will help
    making it up the hill in baja on surf trips. Thanks for all your help @dillonk1602
    BassAckwards likes this.
  2. Feb 15, 2018 at 4:19 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
  3. Feb 15, 2018 at 4:20 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    what do u have on the truck ? so fair as engine upgrades?
  4. Feb 15, 2018 at 6:09 PM
    ZZ
    @dillonk1602 I have a 5 speed manual. So far all I have is the Volant cold air intake system. I just bought the pedal commander and doug thorley headers but waiting on shipping so nothing is installed yet. I’m hoping that gives me some punch but I think the re gear will be a good call to help me make it up a steep dirt hill?
  5. Feb 16, 2018 at 7:37 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    auburn positraction diff with 4.10 gear that way if u do go up in tire size you will be all good and still have some power and it will help with all the camping stuff too.
  6. Feb 16, 2018 at 7:52 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    OEM gearing in are trucks are 3;58 gear, So that will be a good jump 4;10 still getting power but not killing your truck with high rpms.
  7. Feb 16, 2018 at 8:39 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    4.10's are nice...that's what comes standard in the 4wd 5-spd. My first gear is so nice and short that I can climb in and out of anything without much issue (aka open diffs).
  8. Feb 16, 2018 at 9:51 AM
    ZZ
    NICE Thanks for the information!! Sounds like the 4:10 re gear and auburn positraction is the call!!! Any suggestions on where to buy the 4:10 re gear kit? @dillonk1602 sent a good link for the auburn positraction. Thanks again for the input!!
  9. Feb 16, 2018 at 10:24 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    are u in san diego ?
  10. Feb 16, 2018 at 10:25 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    i have a place that can do the install or do you just want parts ?
  11. Feb 16, 2018 at 12:16 PM
    ZZ
    @dillonk1602 yes i am in san diego, chula vista to be exact, the south part. i have a small used car dealership with a shop but if you have a guy that you can recommend i wouldn’t mind checking him out. any suggestion to buy the re gear parts would be cool too. Thanks again for all your guys help!!
  12. Feb 16, 2018 at 12:39 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    ya call my boyz at pro gear tell them that dillon kendall sent you and crag owns it
    (858) 571-1158
    7948 Ronson Rd, San Diego, CA 92111
    if you dont want install then they can get you the parts! let me know how it gose
  13. Feb 16, 2018 at 8:53 PM
    ZZ
    @dillonk1602 Right on!! I’ll def reach out to them and hit them up!! Thanks for all the help, hopefully i’ll be charging baja soon with these upgrades and do better going up those hills!!
    dillonk1602 likes this.
  14. Feb 18, 2018 at 8:56 PM
    ZZ
    I installed the Pedal Commander today and I defintely feel a difference, the lag in first gear is a lot less. When I get the D. Thorley headers (being shipped) installed I should be able to feel a big difference. Keep shredding!
    dillonk1602 and Torspd like this.
  15. Feb 19, 2018 at 7:34 AM
    #35
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    will do let me know if you need anything other then that stuff
    :bananadance::mudding:
  16. Nov 6, 2018 at 5:13 PM
    #36
    seeyacea
    seeyacea New Member
    Nick
    Hey man, I know this feed is alittle in the past but are all the parts for your turbo setup custom fabricated? I cant even find a manifold for my life if I wanted to. Have a 2015 4 banger myself and need more power for the build I am going for and also dont want to spend 4k on the URD kit which doesnt play nice with automatics anyways.
  17. Nov 7, 2018 at 3:08 PM
    #37
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    The manifold and downpipe I got from Shanghai Waystar on Alibaba. The turbo is a GT2871r. Everything else was individually sourced, and the only real fab work was the intercooler piping for the most part.
  18. Nov 7, 2018 at 9:53 PM
    #38
    seeyacea
    seeyacea New Member
    Nick
    Can’t thank you enough, have been looking for this for forever, will update with pics when I pull the trigger
