2005+ Tacoma ICON RXT Rear Suspension
Discussion in 'SDHQ Offroad' started by SDHQ OFFROAD, Jul 13, 2017.
  1. Jul 13, 2017 at 9:05 AM
    SDHQ OFFROAD
    SDHQ OFFROAD [OP] Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    The 2005-UP Toyota Tacoma is an extremely reliable truck that has served as a versatile platform for drivers seeking the ultimate off-road adventure. From the brutal deserts of the Southwest, to the slickrock of Moab, to the wooded trails of the East coast ICON suspension systems have been put to the test and performed flawlessly for this popular Toyota. ICON Vehicle Dynamics’ engineers have pushed this vehicle to extremes in order to develop the most sophisticated suspension components on the market. Unable to leave “well-enough” alone, ICON is once again aiming to raise the bar in Tacoma performance with the introduction of the RXT Rear Suspension System.
    Through thousands of miles of accelerated testing in our R&D program, ICON has spent over a year identifying limiting factors in OE components and seeking to further extrapolate performance out of this vehicle. In a push to provide unparalleled performance for everything from high-speed desert running to off the grid expedition, the RXT Rear Suspension System was born. The RXT Rear Suspension System includes three all-new 2.5 Series rear shock options and a multi-rate leaf spring that work in conjunction with the ICON rear bump stop kit. Installation of this system replaces the aforementioned “limiting factors” and completely redefines the potential of the 2005-UP Toyota Tacoma with a 20% increase in wheel travel and the ability to adjust the leaf spring rate to compensate for varying vehicle setups. This system will work without the bump stop kit but will decrease travel.
    ICON RXT Multi-Rate Leaf Spring
    To take advantage of the additional travel that the RXT Rear Suspension System offers, ICON engineers had to scrap the OE leaf springs and develop a replacement that addressed issues found in the R&D process. The result is a user-adjustable multi-rate leaf pack that offers a major performance gain for almost every Tacoma setup imaginable. Features like tip inserts and leaf separators reduce friction and increase ride comfort, while a military wrapped front eyelet improves the durability and strength of the leaf spring. To increase the ride quality of the truck and gain additional droop travel, the spring rate has been lowered slightly. While many Tacoma owners will embrace this, there are those who have outfitted their trucks with a significant amount of weight in the form of a bed rack, roof top tent, spare tires, parts, or other additions. Understanding this, the leaf pack was designed with an additional leaf (included with kit) that can be exchanged or added to the pack yielding an additional 10% or 20% spring rate that will handle more "outfitted" vehicles.
    KEY FEATURES
    • 3 user-adjustable spring rates for unique vehicle configurations
    • Military wrap front eyelet for increased durability
    • Galvanized leaf separators reduce friction and aid in corrosion resistance
    • Leaf tip inserts reduce noise and increase ride comfort
    • Potential for increased wheel travel when used with RXT shock (up to 20%) without sacrificing up-travel
    • “ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
    • Direct bolt-in to OEM spring location makes for an easy install
    ICON RXT Rear Shocks
    To complete the RXT Rear Suspension System, three new shock options were developed that could control the suspension throughout this new range of travel. These options include a 2.5 Series remote reservoir shock, a 2.5 Series CDC Valve shock, and a two-tube Omega bypass that provide unique levels of performance to the rear end of the Tacoma. The increase in wheel travel was answered with a unique side-mount eyelet approach that allowed ICON engineers to develop a shock that is shorter in collapsed length, longer at extension, and still fits in the factory mounting location. A large ten inch remote reservoir was added to aid in heat dissipation and resist shock fade during spirited driving.
    ICON RXT Rear Shock
    • Unique side-mounted lower eyelet allows for increased travel while utilizing factory mounting location
    • Vehicle-specific tuned shocks provide increased damping and oil volume
    • CDC Valve technology allows for 10 settings of quick and easy compression damping adjustment
    • Omega Series two-tube bypass allows for 24 settings of compression and rebound damping adjustment
    • Easy-to-adjust detented knobs offer quick adjustability without the use of tools
    • 10” aluminum reservoirs provide generous oil and nitrogen volume for consistent damping as shock temperature increases
    • Shocks are fully rebuildable and revalveable
    • Simple and straightforward installation
    • Made in the USA
    ICON Hydraulic Rear Bump Stop Kit
    • 2.5” travel bump stop reduces rear end ‘kick’ and improves overall performance
    • Position sensitive technology exponentially increases bottom-out resistance
    • Vehicle specific bump stop tune to provide smooth engagement and best ride quality
    • Direct bolt-in to OEM bump stop location makes for an easy and straightforward install
    • Heavy duty 1 ¼” CNC machined nitro steel shaft
    • Multi-stage CAD plated body for maximum corrosion resistance
    • Double sealed high pressure Schrader valve
    • Operating range of 50 – 250 PSI
    • Replaceable noise reducing striker pad
    • Fully serviceable
    Here are the different spring options w/weight & lift heights
    Available to order, PM for pricing
    http://store.sdhqoffroad.com/2005tacomaiconcompletesuspensionsystems.aspx
    If you are looking for individual components, PM me.
    Icon_Madison, hellppy and 2011pretaco like this.
  2. Jul 14, 2017 at 3:02 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    In for video clip....
    :popcorn:
    2011pretaco likes this.
  3. Jul 18, 2017 at 10:16 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    We are hoping to do an install video on our shop Tacoma as soon as everything lands!
  4. Jul 28, 2017 at 10:28 AM
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    Do these give different lifts based on what gen Tacoma you have? I noticed on headstrong off-road they say 2.75 of lift for 2nd gen and 2.0 for 3rd gens with dakars. not sure if that would apply to these leafs
  5. Aug 7, 2017 at 9:01 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Just saw this, sorry about the delayed response. Lift heights will all vary from vehicle to vehicle but it will be minimal (maybe 1/8") from 2nd gen to 3rd gen.
  6. Aug 7, 2017 at 9:01 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    These are in stock by the way!
  7. Aug 7, 2017 at 9:06 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  8. Aug 25, 2017 at 8:51 PM
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    Well shit, here I go again . . .
  9. Aug 29, 2017 at 8:53 AM
    CR2014Sport
    CR2014Sport Well-Known Member
    Craig
    SoCal
    2014 Sport
    Stuff... Need more stuff
    I like the universality of the leaf springs but the system as a whole is overkill for my needs.. Do you have the specifications for the shocks (collapsed and extended length)? I would like to see what other options I would have for the rear shocks.
    Thank you.
  10. Aug 29, 2017 at 1:12 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    They do have standard travel shocks as well. I will have to look into actual collapsed and extended lengths.
  11. Aug 29, 2017 at 3:06 PM
    CR2014Sport
    Craig
    SoCal
    2014 Sport
    I don't mind the amount of travel the shocks provide... I just not sure I need the bump stops and the bypass with 24 settings..
  12. Aug 29, 2017 at 4:05 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Bumpstops are not required and the bypass is one of the 3 configurations that they offer. They offer a 2.5" piggyback, 2.5" piggyback w/ CDC, and 2.5" Bypass.
  13. Sep 5, 2017 at 7:38 PM
    danielhfranks
    danielhfranks Well-Known Member
    San Clemente, CA
    5th Gen 4Runner
    Question on these, what are the lift heights on a 2nd gen? Guessing those heights were taken for the 3rd gen as it is in the pic.
    Thanks!
  14. Sep 6, 2017 at 5:21 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    According to Icon, within 1/8" of the 3rd gen
  15. Sep 6, 2017 at 5:26 PM
    danielhfranks
    San Clemente, CA
    5th Gen 4Runner
    Appreciate it! Thank you
  16. Oct 23, 2017 at 10:11 PM
    mventure._
    mventure._ Active Member
    Mark
    Phoenix, AZ
    '15 Silver V6 Tacoma TRD Sport 4x4
    3" Lift with Fox 2.5 RR extended coilovers, Total Chaos UCAs, OME Dakar leaf packs, Archive Garage shackle flip kit, Archive Garage U-Bolt flip kit, Wheelers Superbumps, Wheelers extended brake lines, Bilstein B110 rear shocks, 1.25" wheel spacers, 295/70r17 Cooper STT Pros, SDHQ 3-way spare tire carrier in bed
    I would also like to know the extended and collapsed lengths of these shocks if you can look into it! Thanks
  17. Oct 24, 2017 at 12:58 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    24.75" Extended (Measured from lower eyelet to the top of the top cap)
    14.5" Collapsed
  18. Oct 24, 2017 at 1:12 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    This is what I was going to ask... If the air bumps are required... No they are not.
    I have a 2nd gen reg cab and have been looking at this as a future upgrade minus the air bumps, I'm more interested in the leaf pack it would be nice to do the low end 2.5 resivior shocks.
  19. Oct 28, 2017 at 8:09 PM
    Dea1276
    Dea1276 Active Member
    Vista CA.
    2011 TX/PRO
    OME 885 on 5100s, Dakar springs, b110 5100 rear, LR UCA, Wheeler's superbumps.
    Wonder how these would work with ome leaf pack. Currently running b110 5100s but have been thinking about an upgrade.
  20. Oct 30, 2017 at 7:37 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    They have not been tested with the OME leaf pack to my knowledge but from my understanding is that the shock will offer more travel than what the Dakar leaf pack can provide.
