2005 tacoma prerunner to 4x4 conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Therunner, Mar 4, 2019.
  1. Mar 23, 2019 at 10:59 AM
    Therunner
    Therunner [OP] Active Member
    Portland, OR
    2003 4runner sport 4x4
    3in rough country suspension lift. 285/70r17 GY UltraTerrains on 2016 4runner wheels. Also have 2005 DCSB tacoma prerunner. Currently stock, working on 4x4 conversion then will get lift and bigger tires.
    Also for anyone looking for hook up and indicator light while still only using a momentary switch to activate the ADD I found that when the ADD is engaged the gree with black stripe wire and white with black stripe with have continuity, and then are open when it is disengaged. This being said you can hook up wiring to these wires that you can use to illuminate a light only when the ADD is engaged.
    Hope that helps for anyone looking to use a momentary switch with indicator light.
    I will try to make a further write up on this with pics of wiring hardness and label corresponding wires.
    Longtech likes this.
  2. May 29, 2019 at 7:24 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Have fun, I really enjoyed doing this conversion on mine.
  3. Mar 15, 2021 at 8:45 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    So what happened at the end? Did you completed the conversion?
