2005 Tacoma will turn over but not start.
Discussion in 'Technical Chat' started by baughman, Jul 18, 2016.
  1. Jul 18, 2016 at 6:59 PM
    baughman
    baughman [OP] New Member
    I have a 2005 Toyota Tacoma that will turn over but will not start. So far I have replaced both the fuel pump relay and the EFI relay. I have also replace the fuel pump. I brought the oil level up between the two marks in case it was a sensor for the oil level that would not let it crank. I have pulled a plug, placed it in a coil pack, put the plug against the engine, turned over the ignition and did not see a spark. Can anyone tell me where to go from here or if I have not done something right? Thanks in advance.
  2. Jul 19, 2016 at 9:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. Jul 21, 2016 at 9:23 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Have you checked the CEL codes? Something this bad will almost always trigger the CEL and store one or more codes that can be read with a scan tool (advanced or auto zone will pull the codes for free but that's problematic if it won't start so you can get to one.) The scan tools are cheap enough everyone that is a DYI-er ought to have one anyway.
    You can always check fuel pressure to see if the pump is working. Sort of sounds like a crank or cam position sensor failure if there really is no spark. From experience, you ARE using the real Toyota key and not a wal-mart copy? :) That immobilizer is pretty clever and will kill both fuel and spark if you use a bogus key.
  4. Jul 21, 2016 at 9:31 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    When this is occurring, is your immobilizer light flashing or off? If it is flashing, it may be the key or related to the immobilizer. Some Tundras have issues with their immobilizers
  5. Jul 24, 2016 at 8:42 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    You need to check the code first to see if it is related to the immobilizer system. If the truck starts and then shuts off in about 2 seconds then it is the immobilizer/ECU sensing a bad code from your key. If the truck just cranks and does not start then this is harder to figure out. Based on my experience over the last 3 months it could be a wiring harness or the transponder amplifier.
  6. Aug 5, 2016 at 5:59 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Baughman, did you get your truck fixed? Interested in hearing what the problem was.
  7. Sep 2, 2016 at 6:38 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Baughman, any updates?
  8. Sep 8, 2016 at 7:39 AM
    98tacoma27
    Ben
    Not Beech Creek
  9. Sep 24, 2016 at 3:55 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Sure would like to know if you got your problem corrected and what the fix was.
  10. Nov 18, 2016 at 1:08 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    any updates?
