2005 Xrunner- NO POWER and Black smoke.
Discussion in 'Underdog Racing Development' started by rockstar626, Aug 8, 2012.
  1. Aug 8, 2012 at 7:16 AM
    rockstar626
    rockstar626 [OP] Member
    Virginia
    05 XRUNNER-URD
    URD supercharger
    Hi,
    First post here, but could really use some help right now. I work for a small auto dealership and we recently sold a 2005 Toyota Tacoma Xrunner. It has a URD Supercharger on it, what stage, I do not know.
    It has been running great until now. We sold it about 1 month ago and it only has 27k miles on it.
    The customer had it towed it because there was black smoke coming from the tailpipe and absolutely no power at all!! I dont even know where to start. I have tried calling URD and they have not gotten back to us yet, so I am reaching out to the community to see what we should do first. I wanna take care of this customer and the local Toyota Dealer is scared to mess with it. Any advice would be appreciated.
    ps Traction oil is full. Belt seems OK. We obviously do not have the scan tool to talk to the truck.
  2. Aug 8, 2012 at 7:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like too much fuel. What else is on the truck as far as URD and aftermarket components?
    Also, you can try these guys. You may get a faster response or possibly the previous owner...
    http://www.xr-underground.com/
  3. Aug 8, 2012 at 7:42 AM
    rockstar626
    Virginia
    05 XRUNNER-URD
    URD supercharger
    Not sure. It looks like its pretty stock. No exhaust work appears to have been done either. Ill try to get a pic on here soon.
    When we took it to Toyota, they said that when they "clear" the codes, the truck runs good for 3- 4 minutes, then goes back into a closed loop. Thats when the problems begin again. I have been told that Toyotas scan tool can not talk to the URD set up. Is this correct?
  4. Aug 8, 2012 at 7:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    That, I do not know. What code(s) does it throw? Or is it spefically a URD code?
  5. Aug 8, 2012 at 7:53 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    How can you be absolutely sure the URD is to blame?
  6. Aug 8, 2012 at 7:57 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    :rolleyes:
    is blame being tossed or help being requested by someone that may have the knowledge to help? like the maker of the SC?
  7. Aug 8, 2012 at 7:59 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I just ask because OP stated he doesn't know where to begin, but it seems as if the only thing he is concerned with is the URD.... Just trying to help think outside of the box a little.
  8. Aug 8, 2012 at 8:03 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Oh I feel so confident now.
  9. Aug 8, 2012 at 8:05 AM
    rockstar626
    Virginia
    05 XRUNNER-URD
    URD supercharger
    We dont know the SC is to blame. All I can give is symptoms. No check engine light. No nothing other than symptoms and a modded truck that we can not talk too or reset. If it was stock this would be a whole lot easier, but I have faith that someone in this community can say"start here".
  10. Aug 8, 2012 at 8:05 AM
    TRD6Speed
    Bill
    East Hartford, CT
    I think he is troubleshooting and seeing that the only visible mod is the SC he is "beginning" correctly by trying to contact Gadget or others with the knowledge to prob help before he starts wrenching or causing more damage.
    OP.....nice to see you taking care of the your customer. GL with fix
  11. Aug 8, 2012 at 8:07 AM
    TRD6Speed
    Bill
    East Hartford, CT
    beat me to it.......good stuff
  12. Aug 8, 2012 at 8:17 AM
    rockstar626
    Virginia
    05 XRUNNER-URD
    URD supercharger
    No check engine light is on and I am being told that there are no codes in "Toyotas ECM". I am being told that there is a seperate programmer to adjust the URD to make it do different things. So perhaps there is an error code in the URD. Does this make sense?
    One more thing. Toyota has said that when they "clear" the ECM, the truck runs fine for 3-5 minutes, and then right back where we started, bogging down and black smoke.
  13. Aug 8, 2012 at 8:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it makes sense. They come with fuel management controllers. Just need to know which one and perhaps we can find the software for it.
  14. Aug 8, 2012 at 8:25 AM
    TRD6Speed
    Bill
    East Hartford, CT
    ya...they have fuel and igntion controllers.........If it runs fine for 3 to 5 minutes then bogs it def sounds like gas/air ratio is getting fubar'd. I think you are on the right path with getting the controller identified then programmed correctly.
    dammit.....98 tacome was faster....damn BF! flying the chopper
  15. Aug 8, 2012 at 8:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think it should be kept simple too and look for a loose vacuum or pipe as Whipper asked. Maybe even a loose wiring connection for the controller.
  16. Aug 8, 2012 at 8:29 AM
    TRD6Speed
    Bill
    East Hartford, CT
    But wouldnt that cause issues right from startup......if a vac or hose was loose it wouldnt run right for a few then bog and start choking. It would have no pressure from the get go.
  17. Aug 8, 2012 at 8:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    That all depends on what is exactly wrong with it. It runs in open loop but "dies" when it hits closed loop.
  18. Aug 8, 2012 at 8:47 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    where the injectors changed out? maybe pull them and see what they are looking like. Ive been running into a very similar problem on my aircraft and the injectors are clogged from shitty fuel.
  19. Aug 8, 2012 at 9:07 AM
    rockstar626
    Virginia
    05 XRUNNER-URD
    URD supercharger
    This. This is exactly what we were told at Toyota. You just worded it better than me.
  20. Aug 8, 2012 at 9:07 AM
    rockstar626
    Virginia
    05 XRUNNER-URD
    URD supercharger
    Where would this be located?
