2005 Xrunner- NO POWER and Black smoke.
Discussion in 'Underdog Racing Development' started by rockstar626, Aug 8, 2012.
  1. Aug 9, 2012 at 12:07 PM
    #41
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    With all due respect, we are just attempting to help...
    Number 1: you will get more help on xru, not many URD's around here.
    Number 2: If you need to talk to Gadget, then bombard him relentlessly.
  2. Aug 9, 2012 at 12:17 PM
    #42
    GodHatesUsAll
    GodHatesUsAll Reign in Blood
    Satan
    Six Feet Under
    05' Black Sand Pearl XRunner
    TRD Blower//APR X-1//668cc Primaries & 7th inj//URD 2.8"&NST OD Pulleys//AFE StageII Si CAI//URD Fuel Pump//JBA GenII lT's//URD S/S//URD Lite Flywheel//Competition Clutch StageIII//NST Lite Pulleys//Sittin Sic Front coils/Rear Mono leafs//
    So ur saying ur managers cell phone doesn't have voicemail?
  3. Aug 9, 2012 at 12:18 PM
    #43
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Make sure the Supercharger is torqued correctly on the manifold; it wouldn't be the first time the bolts loosen up. These things really don't like vacuum leaks.
  4. Aug 9, 2012 at 12:19 PM
    #44
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you try the part about unplugging the 7th injector or were you too busy trying to blast him for his post?
    Ever hear the phrase, 'don't kill the messenger'? :rolleyes:
  5. Aug 9, 2012 at 12:25 PM
    #45
    GodHatesUsAll
    Satan
    Six Feet Under
    None of URDs mki's or mkiis mount to any manifold
  6. Aug 9, 2012 at 12:29 PM
    #46
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, ok. Still sounds like a massive vacuum leak to me. Also and I know this is simple but with the engine running tap the MAF sensor lightly with the handle of a screw driver; if the idle fluctuates you need a new MAF but then you already knew that...right? Could be the EGR system, too.
  7. Aug 9, 2012 at 1:05 PM
    #47
    rexrunner
    rexrunner Member
    gt35r
    don't blame gadget. Your dealership sold the truck and made the profit. Not gadget. Your techs need some training. There is.no reason why a regular scan tool can't read from the ecm. The urd psc does not affect that. Its a piggyback. You need to see what the maf is seeing. Open loop/closed loop function.
    What codes are you throwing?please don't tell me you keep erasing them without reading them. So what codes?
    The urd psc goes inline between the sensors. Check the voltage at the psc to make sure its hot.
  8. Aug 9, 2012 at 1:31 PM
    #48
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Thanks for all the help folks.
    I have been in touch with the OP.
    We will get it sorted out.
    Lets turn down the wick here. I know everyone is doing their best to help and have the greatest intentions and in no way meant any harm.
    G
  9. Aug 16, 2012 at 5:17 PM
    #49
    Nathan88
    Nathan88 Member
    Nathan
    Ga
    06 PreRunner SR5 TRD Sport
    DoubleDin Pioneer P3200 dvd headunit, Big Country chrome side step bars, 25% tint windows, Bak rollbak bed cover.
    Sounds like if it had an supercharger installed and with the problems stated. You may need to get the ECU reflashed. That's a must after installing a supercharger.
  10. Aug 16, 2012 at 5:19 PM
    #50
    Nathan88
    Nathan88 Member
    Nathan
    Ga
    Another idea is to check the plugs and make sure they installed the correct type of plug for the supercharger.
  11. Aug 16, 2012 at 6:10 PM
    #51
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    update?
  12. Aug 16, 2012 at 6:30 PM
    #52
    GodHatesUsAll
    Satan
    Six Feet Under
    This has the URD blower installed not TRD, no ECU reflash needed
  13. Nov 29, 2012 at 8:01 AM
    #53
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Was it fixed?
  14. Nov 29, 2012 at 11:45 AM
    #54
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    That makes sense. Since they are not MFG specific.
