2006 2wd vibration
Discussion in '4 Cylinder' started by gcm223, May 30, 2018.
  1. May 30, 2018 at 4:50 PM
    gcm223
    gcm223 [OP] New Member
    2006 Tacoma Base 2wd
    i have a 06 4 cyl 2wd basic Tacoma. It has 69000 miles on it. Over the last couple hundred miles I have noticed a dull vibration that I can feel through my gas pedal foot.
    It happen during acceleration between 35 and 60mph. It does not vibrate accelerating at lower or high speeds.
    It isn't the tires because it only happens when my foot is in the gas. When I level out at 55 or 60 the vibration slows down but does not completely go away.
    Any ideas where to start looking for this? Timing chain? Transmission ? I don't have a clue.
    If I haven't explained this well, let me know if u need more information
    Thanks.
  2. Jun 1, 2018 at 11:10 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Check the driveshaft and U-joints... that's all I can think of right now.
  3. Jun 4, 2018 at 3:18 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    As @DGXR said check the u-joints. It could also be that the center support bearing needs to be replaced.
  4. Jun 4, 2018 at 3:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not a legit eliminator. It might not be a balance issue, but a broken belt issue.
    Best way is to rotate tires front to rear and see if anything changes.
    It's free, worth a shot.
