2006. 4.0 V6 head gasket overheating > REBUILD
Discussion in 'Technical Chat' started by Justintheegreat, May 12, 2019.
  1. Nov 27, 2019 at 8:34 PM
    #141
    tomjo1
    tomjo1 Well-Known Member
    Tomjo
    Taiwan
    2007 Black Tacoma Sport
    2.5inch high life kit
    So even DYNICRON in Stockton CA removed .004 On your heads ?
    And how about the engine light disappear ?
  2. Nov 27, 2019 at 8:39 PM
    #142
    Justintheegreat
    Justintheegreat [OP] Well-Known Member
    Northern CA
    06 DCSB Sport
    yes thats very very minimal. and your heads will warp before you block does. if your block is warped you are pretty much screwed. IMO
    what year is your truck and how many miles?
    GT7 likes this.
  3. Nov 27, 2019 at 9:34 PM
    #143
    tomjo1
    Tomjo
    Taiwan
    2007 only running on 60k .....
    Whats happened on mine truck , it's normally before , till one time , i try to hydrogen and carbon removal on Sep , one day , when i check my water tank , i found the water was less then the high line ... then i add on , then driver , recheck the water keep less .... so i check and found the bubble .... damm...
  4. Nov 27, 2019 at 9:44 PM
    #144
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    yes.
  5. Nov 27, 2019 at 9:49 PM
    #145
    Justintheegreat
    Northern CA
    06 DCSB Sport
    have you replaced anything? water pump or thermostat? is it overheating? i would try the cheapest first.
    defiantly do a coolant flush and get out all the air bubbles
  6. Nov 27, 2019 at 9:58 PM
    #146
    tomjo1
    Tomjo
    Taiwan
    Water pump replace on 55K , no any overheating ... temperature always keep on 88-90Degree C。
    can't find any wtaer leak from my engine or water pipe , water pump ....
    Only one thing i do was hydrogen and carbon removal on Sep... after that i start to found my water will be less.... and bubble comeup !!
  7. Nov 28, 2019 at 1:01 AM
    #147
    tomjo1
    Tomjo
    Taiwan
    Here is my situation now~
    When start can't see any bubble , but after Water temperature 80 degrees C , the bubble show up .....
  8. Nov 28, 2019 at 1:03 AM
    #148
    Justintheegreat
    Northern CA
    06 DCSB Sport
    i say you just bleed the system for any air bubbles. purge it.
  9. Nov 28, 2019 at 2:17 AM
    #149
    tomjo1
    Tomjo
    Taiwan
    But at same time , my reservoir water will decrease from high to low .....
    it's never happened even i replace the water pump on 55K ...
  10. Nov 28, 2019 at 2:22 AM
    #150
    Justintheegreat
    Northern CA
    06 DCSB Sport
    you said you performed a carbon test in your radiator?
    positive carbon is inside you cooling system?
  11. Nov 28, 2019 at 5:46 AM
    #151
    tomjo1
    Tomjo
    Taiwan
    Not yet , buy the test already , wait for delivered.....
  12. Nov 28, 2019 at 9:21 AM
    #152
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    How would resurfacing the heads have any impact on the chain? Wouldn't the chain tensioners make up for any small difference there is?
  13. Nov 28, 2019 at 1:18 PM
    #153
    Justintheegreat
    Northern CA
    06 DCSB Sport
    I resurfaced my heads in case there was any warpage
    I didnt wanna do this whole thing and later on find out it was a waste bc my heads are warped and I didnt resurface.
  14. Nov 28, 2019 at 1:42 PM
    #154
    Fullboogie
    Dave
    Houston
    Yes, I know why you did that. My question was for the others who don't seem to understand it.
  15. Nov 28, 2019 at 1:44 PM
    #155
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Can these motors be bored over? I vaguely recall Sth about a cylinder sleeve making that impossible but not sure if I got motor merge lol
  16. Nov 28, 2019 at 1:56 PM
    #156
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Not really, need sleeves
