2006 Limited Slip Differential - Mobil 1
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mnerren, Jun 5, 2011.
  1. Jun 5, 2011 at 7:12 AM
    mnerren
    mnerren [OP] 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    I just stopped by the auto parts store and picked up 3 quarts of Mobil 1 75w 90w differential oil for my 2006 with LSD. The bottle says it is made for a LSD, I haven't put it in yet, but now I was wondering if that is okay for the Tacoma with LSD. I have a 2 wheel drive Tacoma with the a LSD rear end.
    Anyone using the Mobil 1 synthetic stuff?
  2. Jun 5, 2011 at 7:24 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Do not use the Synthetic for a limited slip. The LSD will slip and chatter.
    Just get a tube of friction modifier and use that with regular dino oil. Add the entire tube of modifier and then fill the diff as you would.
  3. Jun 5, 2011 at 7:39 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  4. Jun 26, 2011 at 6:54 AM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    I have an 08 AC and I use it primarily for towing a 4K lb trailer, it has 20Kmiles(bought it with 10K a year ago and all it had hauled is air) so it's time for a rear-end lube change. Just a few questions:
    Is 75-90 the recommended weight gear oil for the rear on my 08?
    Does it need a gl4 or gl5 rating?
    Is the LSD lube something I can get at the local auto store?
    Any other info on this would be helpful
    Thanks,
    paul
  5. Jun 26, 2011 at 9:36 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Doesn't the owner's manual tell you the type oil (GL4 or GL5 and weight)? I'd just follow that.
    But I've read the GM LSD friction modifier works best... get it at a Chevy or GMC Truck dealer prolly.
  6. Jun 26, 2011 at 9:42 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
  7. Jun 26, 2011 at 5:36 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    You'll probably find the Sta-Lube Equa-Torque Limited Slip Additive in a blue bottle at the auto parts stores (that's where I found mine). A lot of the Toyota dealerships use the same stuff. Here's a link to it so you know what you're looking for:
    http://www.amazon.com/CRC-Sta-Lube-Torque-Friction-Modifier/dp/B003TGCK7S
  8. Jun 26, 2011 at 6:25 PM
    psmcn
    Paul
    Rockville Md
    Thanks for the replies. I would look at the manual but I lent my truck to family this weekend. I'll check for sure tomorrow.
    Paul
  9. Jun 27, 2011 at 8:53 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I used Trans-X lsd additive that I picked up at Autozone with regular gear oil and it works perfect.
  10. Jun 27, 2011 at 10:24 PM
    DCtaco05
    DCtaco05 Well-Known Member
    dustin
    petaluma
    05 tacoma trd
    bone stock.. not for long
    i believe GL-5 superseeds GL-4 correct me if im wrong :notsure:
  11. Jun 29, 2011 at 10:51 AM
    JD2
    JD2 Member
    Western Washington
    05 TRD Sport Double Cab
  12. Jun 29, 2011 at 11:14 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I wouldnt add the whole tube of the friction modifier at once. Add about half if it chatters add some more. If you add the whole tube your limited slip may turn into an open diff...
  13. Jun 29, 2011 at 11:23 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I have been running FULLY SYN Amsoil severe gear 75-90 WITH Amsoil LSD modifier for 30k+ miles and NO problems!! I have a 08 LSD Sport
    Don't believe everything you read on the interent from the above ...that do not have the LSD 05-08s
  14. Jun 29, 2011 at 11:29 AM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    I used Royal Purple, no need for additives. No chattering what so ever.
  15. Jun 29, 2011 at 4:02 PM
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    Going on 90k with the same set up. Amsoil is all I use in all my vehicles, it's all I've put in the taco (motor oil as well) and no problems.
