2006 Prerunner oil fill cap question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glwood6, Oct 31, 2009.
  1. Oct 31, 2009 at 12:55 PM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Was checking the oil and oil fill cap on the 2006 Prerunner 4.0L I purchased a couple of weeks ago, and noticed a small bit of that light tan colored goo on the oil filler cap. The oil on the dipstick looked perfectly clean, and with the engine running I could see the oil down in the engine through the filler tube squirting and moving around, perfectly clean and clear...
    Is this a big concern? Is the tan colored stuff on the inside of the oil filler cap possibly due to the dealer power washing the engine bay and maybe some water got into that cap and mixed with the oil, or possibly some condensation on the inside of the cap (we recently had some major rain/snow)? I know the engine bay got power washed recently, there's pretty good evidence of water splashing all around.
    I cleaned up the cap and am going to keep an eye on the oil pretty closely for the next few days and see if any of that oil/water mixture seems to reappear. BTW, the engine has 49.6k, and there is no evidence anywhere else of water/oil leaks. Should I look for anything else in particular? Thanks. I'm still a 2nd gen newbie :cool:
  2. Oct 31, 2009 at 12:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its from condensation. If you do alot of short trips, condensation can build up and cause that. Pretty normal in colder climates.
  3. Oct 31, 2009 at 12:58 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Great. I was hoping that might be the case.
  4. Oct 31, 2009 at 3:50 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Chris is right (like usual), with short trips, the engine hasn't had sufficient time to warm up and thus the moisture hasn't had time to evaporate. If you take shorter trips, I would suggest changing your oil more frequently than if you mostly traveled on highways.
  5. Mar 13, 2015 at 9:20 PM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I checked out a 2010 v6 spd tacoma last weekend, and noticed the same...slight tan build-up under cap.
    I guess it's the heavier tan sludge you should worry about.
  6. Mar 14, 2015 at 5:25 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Changed the oil in my 09 and I noticed a nickel sized amount.
    No biggee, wiped it off and called it good.
