2006 Tacoma 3" Spacer lift questions
Discussion in 'Suspension' started by hockeyplayer47, Mar 7, 2013.
  1. Mar 7, 2013 at 2:39 PM
    hockeyplayer47
    hockeyplayer47 [OP] Member
    David
    North Carolina
    06 Tacoma V6 SR5 4.0L 4x4
    2.5" Front Lift 1" Rear Block Chrome Exhaust Tip Cherry Bomb Glass Pack Westin Bull Bar Black UWS Tool Box 5% Tint Aftermarket Radio Fog Light Anytime Mod Black Billet Grill Black Headlight Housing 6000k HID Smoked Taillights
    So i am new to this forum and i am looking at lifting my truck. I would like to go with 17x9 Dick Cepek DC-2 Rims with 4.5" BS? And a 3 inch lift. What is the biggest tires i can fit without having to trim anything?
    Specs:
    2006 Toyota Tacoma V6 SR5 4x4 4.0L Double Cab Long Bed
    1) Dick Cepek DC-2 Rims, 4.5 BS
    2) Tuff Country 3" Suspension Lift
    http://www.suspensionconnection.com/cgi-bin/suscon/52907.html
    3) Preferably Nitto Trail Grapplers. I want to stick around the same width of tire as 265/75/R16(what i have on stock truck now)
    Thanks Guys
  2. Mar 7, 2013 at 3:35 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    265/70/17. If you'd go with a 285 width tire you'd need to do trimming.
  3. Mar 7, 2013 at 3:40 PM
    hockeyplayer47
    David
    North Carolina
    Dang. The 285/70/R17's are a little bit skinnier than 265/75/R16's right? I dont really want skinny tires ya know?
  4. Mar 7, 2013 at 5:53 PM
    jtav2002
    Josh
    Reading, PA
    A 285 tire is wider than a 265 tire.
  5. Mar 7, 2013 at 5:54 PM
    jtav2002
    Josh
    Reading, PA
    A 265/70/17 would be pretty much the same overall size as the 265/75/16 you have now, just a little less sidewall since the difference is made up by the larger wheel.
  6. Mar 7, 2013 at 5:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Your going to hear this from most people on here but if you can try and stay away from spacer lifts. Full suspension lifts is what you will want in the long run even if you dont off-road a lot. Its def worth it to save up the extra money and go that route. You can go with 285's but you will need to remove the front mud flaps and do some minor trimming, nothing a small dremel cant fix.
  7. Mar 10, 2013 at 6:39 PM
    hockeyplayer47
    David
    North Carolina
    Dang man, i'll prolly just do that. Im thinking just forget doing the spacer lift, and save up for the 6" full suspension lift, what i originally wanted.
  8. Mar 11, 2013 at 7:01 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I mean a lot of people on spacer lifts but I hear more bad reviews on them then good reviews and I know some people that went from a spacer lift to a suspension lift and they said its a night and day difference.
