2006 Tacoma Double Cab Bed Repaint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by haouliboy, Jan 8, 2008.
  1. Jan 8, 2008 at 4:00 PM
    haouliboy
    haouliboy [OP] Member
    I was wondering if anyone has painted their bed. Not quite sure the best way to go about it. any suggestions? open to all ideas
  2. Jan 8, 2008 at 4:06 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    now are u talking inside or outside? inside, i'd see no reason to...just wondering
  3. Jan 8, 2008 at 4:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    same here. if you are talking about inside....maybe a spray on bed liner that matches the paint??
  4. Jan 8, 2008 at 4:38 PM
    haouliboy
    i just aquired this truck and the bed has been worn pretty good on the inside. No dents or damage just won thru the surface coat pretty good in spots.
  5. Jan 8, 2008 at 4:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    in that case, a spray in liner(or roll on....whichever you can afford) my be the way to go then.
  6. Jan 8, 2008 at 4:45 PM
    haouliboy
    i have never seen a spray in liner done on one of these before. does it look good? it is not your typical bed.
  7. Jan 8, 2008 at 5:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ive heard both pros and cons....some saying they are good to go in these "plastic" beds, some saying they wont stick. i think, if its prepped right, a spray in liner will definitely work. if you dont wanna pay the high premium of a spray on(or the lower cost of a roll on)........maybe get a bed mat for your pick up...........it will hide the bottom of the bed where i imagine the most scratches and dings are, and it will allow stuff to ride int he bed withput sliding all over the place.....i have one and its an awesome investment. or you could buy a bedrug........but its expensive as hell.
  8. Jan 9, 2008 at 5:53 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    No way in hell would I paint my bed. You ever paint latex paint on top of oil base paint?...Go with a color matching Rhino Liner if you want. I have been contenplating doing the Rhino Liner but I don't know if it will stick. I wrote the headquarters and they say they have had no problems..............
  9. Jan 9, 2008 at 6:17 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Go spray on, we do it on the trucks at work, (construction co.) and it is the way to go, that stuff should stick without issue, but to be safe call first.
  10. Jan 12, 2008 at 1:32 PM
    haouliboy
    okay after calling around to several paint shops ect. i called my buddy who does buff and scratch removal on our cars. this came as his suggetion and i have seen him do this on other interior panels on older cars. simple and cost only a few bucks.
    motor oil.
    pour it on a rag or little bits at a time and spread it evenly around the bed. not only does this help for sratches but also for beds that are showing sign of oxidation. make sure to park it in the sun light so it can "bake in" longer the better. if you have to, do a second treatment. after your done make sure to wipe down any excess with clean dry towels.
    i'll post the results later. sorry i didnt take any before and after pictures. errr
