2006 Tacoma ignition coil problem-condensation in oil cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harleymandj, Jan 16, 2019.
  1. Jan 16, 2019 at 8:24 AM
    harleymandj
    harleymandj [OP] New Member
    Bobby
    memphis,TN
    06 tacoma
    Has anyone had any trouble with coil packs ? i have changed #3 coil twice in less than a year. I also have a condensation problem , white build up under oil cap only in winter. Im not running hot , smoking or losing coolant. Any Ideas ? My Tacoma is a 06 with 197,000 miles on it. Im wondering if its time to trade in. thanks
  2. Jan 16, 2019 at 8:59 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I'm curious if you have changed you spark plugs recently. If so what did you install? Did you use Toyota coil packs or aftermarket?
  3. Jan 16, 2019 at 9:57 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    People will tell you the white deposits are the result of a lot of short trips - engine not getting fully warmed up. It's my belief that in addition to this, winter does not help. I believe it's damp in Memphis year round for the most part. Correct me on this if I am wrong.
  4. Jan 16, 2019 at 11:03 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Can't help you with the coil packs. My 2006 2.7 has 149,000 miles and all coils are original units. Put in new Denso iridium spark plugs at 99,000 miles.
    The white film under the oil cap is most likely what Lester said. Once or twice a month, be sure the engine gets to full operating temperature AND STAYS THERE for at least 20 minutes. Take the long way to the store. Go for a scenic drive. Just run it for a longer period so it gets good and hot. Highway cruising is best, IMO.
  5. Jan 16, 2019 at 12:15 PM
    jmanscotch
    jmanscotch Texan
    Jake
    Colorado Springs
    Lexus GX460
    These.
    I get an off-white goop under my oil cap, my daily drive is about a mile and my truck doesn't get up to temp. Experienced these a lot in past cars too. Very normal, just signs of not getting the engine up to temp for long enough on a regular basis.
    Use only OEM coil packs if you want longevity, though you will pay for that luxury. Aftermarket doesn't have a good track record, no matter how tempting the price/warranty is.
    Jake
