2006 Tacoma PreRunner 2nd Gen Lower Ball Joint Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BandanaBerg, Oct 3, 2017.
  1. Feb 11, 2021 at 5:49 AM
    #81
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Possibly but 500$ for both I'm good.
    I will work with what I have I know I will happy once it's all together lol
    If I hate it then it's time for unibal lower pivots to match my uppers..
    I hate balljoints
  2. Feb 24, 2021 at 10:45 AM
    #82
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Does anyone know what the dealership would charge to replace the lower ball joints by chance? I just purchased the moog lower ball joints and curious if anyone here has had the dealership do the replacement?
  3. Feb 25, 2021 at 7:18 AM
    #83
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    They may not. You’d likely be far better off to go to an independent.
  4. Feb 25, 2021 at 7:29 AM
    #84
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    When the aftermarket ball joints fail prematurely it will have absolutely been easier...
  5. Oct 28, 2021 at 2:29 PM
    #85
    JB92109
    JB92109 Active Member
    Joe
    2007 Tacoma Sport 4 Door
    Rough Country Lift + 35" Mickey Thompson, Fab Fours Bumper, Superwinch 9.5k Talon, Dreamcatcher+Gunrack
    Do not recommend Mevotech LBJ, see earlier post from Sept 2019. They have failed after only two years.
  6. Jan 19, 2022 at 11:25 AM
    #86
    Eatpocky
    Eatpocky Well-Known Member
    Bay Area, CA
    23' TRDOR DCSB 6MT
    Great write up! Anyone have recommendations on a LBJ? I have MOOG K500017 on my t4r. They've been on there for a little over 2 years now, but are moving quite freely. No play in them yet. Figure i'd order a new set and have them ready to be installed.
  7. Feb 23, 2022 at 3:38 PM
    #87
    Toyota_#1Fan
    Toyota_#1Fan New Member
    2009 Tacoma - TRD Sport
    Very useful write up. I noticed after the install that the clearance from the zerk fitting to the CV axle boot is tight. 2-3mm. I oriented the fitting so the grease release port faces away from the brake rotors. Anyone have suggestions on how to get to the zerk fitting with grease gun. . (Maybe need a needle and push the rubber boot aside ??). I installed the Mevotech. Hope they last .
  8. Jan 24, 2025 at 2:04 PM
    #88
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    Sorry to revive an older thread, but in the OP's original post, it doesn't make mention of the boot cover at the end. The Moog BJ does not have one prior to being installed in the OP's pics. At what point do you put the boot on the new BJ or will it go on at all?
  9. Jan 24, 2025 at 4:24 PM
    #89
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    My recollection is that the boot is there all along, it just isn't really noticeable with the angles in OP's pics. I did this (years ago) and don't remember having to mess with the boot separately, and it most definitely is there.
  10. Feb 6, 2025 at 2:32 PM
    #90
    BandanaBerg
    BandanaBerg [OP] Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    Correct... as I recall the boots were on the ones I installed. I do not recall having to deal with boots. I do remember reading about boots coming separately when doing recon for the job. Pretty sure these had them on them...
  11. Feb 6, 2025 at 2:35 PM
    #91
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    So... I looked over the photos in the OP. You can see the boot on the BJ. It's just a smaller boot. It's tucked right up in there covering the joint.
