2006 Tacoma rear end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by repus1, May 22, 2012.
  1. May 22, 2012 at 2:12 PM
    repus1
    repus1 [OP] Member
    Hawaii
    06TacoDouble4x4
    3inlift
    I have a 2006 Tacoma TRD sport DC 4x4 with LSD rear end. For some time now I have been hearing a rattling type of noise from the rear end. I thought it might be the brake drum or wheel bearing, but I jacked up the rear and put it in drive. No noise at all. I removed the drums and found no issues either. I replaced the U-joints and still didn't fix the noise. Could it be that it would only make noise with a load on it? Also, sometimes when I start from a start on a turn, i hear a clunking sound briefly, then nothing after. What do you think the problem is? BTW.>> the rattling noise is constant from all speeds and independent of gear selection or RPM.
  2. May 23, 2012 at 1:20 PM
    repus1
    repus1 [OP] Member
    Hawaii
    06TacoDouble4x4
    3inlift
    Spare tire is solid, u-joints seem to be also. I haven't checked the brake cable yet, but I am doubtful of that.
    The clank noise is usually only when from a stop position entering a driveway or just turning. I have pretty much eliminated the leafs as the noise, but will still investigate the possibility.
    Currently I have left it in a local independent Lexus/Toyota repair shop for evaluation. I should have a response from them this afternoon.
  3. May 23, 2012 at 1:21 PM
    repus1
    repus1 [OP] Member
    Hawaii
    06TacoDouble4x4
    3inlift
    Oh ya. The clank is only at acceleration forma stop and it does not continue like a CV joint does.
  4. May 23, 2012 at 6:39 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You have trd sport so mech LSD tends to make noise when needs new diff fluid. When was changed last time?
