2006 Turbo Puddle Jumper
Discussion in '2nd Gen. Builds (2005-2015)' started by MrCrowntown, Oct 16, 2016.
  1. Apr 6, 2019 at 11:05 AM
    #701
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Going after these #'s right?!?!
  2. Apr 6, 2019 at 12:30 PM
    #702
    MrCrowntown
    MrCrowntown [OP] Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I will shatter those numbers LOL
    :anonymous:
    Torspd and buyobuyo like this.
  3. Apr 6, 2019 at 12:38 PM
    #703
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    This isn't pictures of a fully dressed engine.
    0/10, erection lost, unsubscribed, called the cops...:rofl:
  4. Apr 6, 2019 at 1:14 PM
    #704
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  5. May 24, 2019 at 9:19 PM
    #705
    raf-1200
    raf-1200 Active Member
    2008/2012 Tacoma 2tr-fe rear wheel drive
    Lowered, turboed, haltech, body kit, mags, 3 inch pipe
    Hey guys. Doing a similar thing with my Tacoma (Hilux here in oz). I went ahead and bought a boomslang harness and have the haltech 1500 elite. Plugged it all in and set the trigger etc exactly the same as the screenshot earlier in this thread. Are there any other things I need to change to get it running? I understand it'll be rough but right now it turns over but won't fire.
    CrownTown any other advice?
    MrCrowntown[OP] likes this.
  6. May 24, 2019 at 9:26 PM
    #706
    MrCrowntown
    Alyn
    Ky
  7. May 24, 2019 at 9:44 PM
    #707
    raf-1200
    CrownTown I thought 36 pages was a lot.. whats that link up to now... 536 pages?!! there goes my weekend hahahaha
  8. May 24, 2019 at 9:55 PM
    #708
    MrCrowntown
    Alyn
    Ky
    We are all massive gearheads so we like to talk a lot of shop :cool:
    Torspd and 05Taco4x4 like this.
  9. May 24, 2019 at 9:59 PM
    #709
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    And we're desperate for aftermarket parts for the 2TR lol
  10. May 25, 2019 at 6:50 AM
    #710
    MrCrowntown
    Alyn
    Ky
    Haha for real!
    BassAckwards and 05Taco4x4 like this.
  11. May 26, 2019 at 8:22 PM
    #711
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Hey man, i think i remember you running the LCE dual comp clutch.. do you have any issues with vibrations while decelerating in 3rd gear? I am having a nasty vibration from 2500-2000rpms in 3rd.. i have narrowed it down to the pressure plate being the culprit
  12. May 26, 2019 at 8:52 PM
    #712
    MrCrowntown
    Alyn
    Ky
    Curious as to what makes you think the pressure plate is causing your vibes?
    I have all heimed joints so i have a lot of vibes and shimmys lol too many to focus them down to the pressure plate
    BassAckwards likes this.
  13. May 26, 2019 at 9:04 PM
    #713
    BassAckwards
    My factory clutch was slipping and tired, so I decided to put a lightweight flywheel and dual comp clutch in it. I never had any vibes while my factory clutch was installed.. Immediately after swapping out the clutch and flywheel, it had vibes while accelerating and decelerating like I described above. I didn't replace the pilot bearing when I did my clutch the first time so I started by dropping the trans again to replace that and eliminate it as a variable. After that, I started trouble shooting and thought it was just the ujoints going out, so I changed them all out. No change, so I decided to finally address my leaky rear ARB locker. Replaced my 3rd with a new built one from ECGS, with no difference. Then started to think maybe my trans was just on it's way out because it's lived a hard 250k mile life. Found a nice used trans for cheap w/ 77k on it and swapped it in, still had the same vibes. Started to read more online and found that lightweight flywheels can sometimes cause issues like this. Had my factory one resurfaced and took out the LCE one, still have the same issues. While I had the trans dropped to swap out flywheels, I noticed the center part of the pressure plate that the input shaft of the trans goes through is loose and has a little play in it. I have eliminated all other variables and it has led me to believe the pressure plate is the problem.
  14. May 26, 2019 at 9:24 PM
    #714
    MrCrowntown
    Alyn
    Ky
    So the center hub is loose? Is it the dampening springs? Sounds like the clutch disc
  15. May 26, 2019 at 9:35 PM
    #715
    BassAckwards
    Correct, center hub is loose. I am not sure what is causing it.. I have a cheap stock clutch coming in I can swap in so I can send this off to clutchmasters to be looked at
  16. May 27, 2019 at 3:55 PM
    #716
    MrCrowntown
    Alyn
    Ky
    I was always concerned with the sprung hub design for rough use. Maybe a solid hub would be better? If you reach out to them, maybe inquire about a solid replacement option
    05Taco4x4 and BassAckwards like this.
  17. May 27, 2019 at 4:10 PM
    #717
    BassAckwards
    Will do, appreciate the tip:cheers:
  18. Jun 29, 2019 at 9:21 AM
    #718
    Boring
    Boring This space unintentionally left blank.
    Arizona
    5-lug regular cab
    yarp
  19. Jun 29, 2019 at 1:24 PM
    #719
    MrCrowntown
    Alyn
    Ky
  20. Jun 30, 2019 at 6:35 PM
    #720
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What are the updates mayun?!
