2006 v6 with 90,000 unknown miles.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cabsav214, Oct 18, 2009.
  1. Oct 18, 2009 at 11:51 AM
    cabsav214
    cabsav214 [OP] Active Member
    NOR CAL
    08 DC 4x4
    I just bought a 06 sr5 tacoma access cab trd 4x4. It has 98,000 on it. It was a lease with 1 owner. I had wrongly assumed that all the service was completed at a Toyota dealer/garage. Basically from 10,000 to 90,000 I have no idea what was done to it. Yesterday I changed the Plugs, fluid in both diffs, changed the oil with mobil 1 and put a k&n oil filter in it, greased the drive shaft, flushed to the coolant, did it all to Toyota specs. The air filter looks ok, going to put a pro dry in it. And changed the cabin air filter that was way dusty. What else do I do? I have no idea how often this guy serviced it.
  2. Oct 18, 2009 at 11:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like you have covered all the bases.
  3. Oct 18, 2009 at 12:01 PM
    cabsav214
    NOR CAL
    08 DC 4x4
    By the way, I did all the above in about 2 and a half hours thanks to all the how to post on this site. Thanks!
  4. Oct 18, 2009 at 12:07 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Did you get a good deal on the truck?
  5. Oct 18, 2009 at 12:09 PM
    cabsav214
    NOR CAL
    08 DC 4x4
  6. Oct 18, 2009 at 12:36 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's great ! Congratulations on the truck and the quick maintenance job ! Over 30,000 a year. Someone did a lot of driving. Hopefully it was a lot of highway driving not much stop and go. Mine had 132,000 when I lost it to rust but it still ran great. I did have to do the water pump plus all the stuff that you did.
  7. Oct 18, 2009 at 1:49 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd do a condenser service. And check the brakes.
  8. Oct 18, 2009 at 5:03 PM
    frankrizzo1
    frankrizzo1 Well-Known Member
    San Diego
    05 Access Cab TRD Prerunner
    5100's at 1.75, Firestone Destination AT 265/75/16
    Nice, congrats on the new truck! You did so many good things with changing everything....... the only other thing I would do is get your transmission fluid changed :thumbsup:
  9. Oct 18, 2009 at 5:05 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Nice find. X2 on the brakes. :)
  10. Oct 18, 2009 at 6:08 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    What does the service manual say about a 90K mile service? My wife's Sequioa recommended a serpentine belt/water pump change. We also changed a couple of seals while they were in there. I'd assume the tacoma is similar but don't know. My 2006 is at 28K miles and going strong. :D
    Edit: I'd also recommend cleaning the throttle body (just did that today on the Sequoia, 131,000 and still going).
  11. Oct 18, 2009 at 7:42 PM
    johnecon2001
    Phoenix, AZ
    At least visually inspect the serpentine for cracking.
  12. Oct 18, 2009 at 11:14 PM
    cabsav214
    NOR CAL
    08 DC 4x4
    Thanks for all the input, I had a friend check the truck out minimally before buying it and said the discs were at 90% and drums at 60% which I thought was pretty good. I was just worried if the previous owner went a long stretch without an oil change. Should I seafoam it? The belt looks good. What about the fuel filter?
  13. Oct 18, 2009 at 11:50 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    you shouldve sea foamed it before you changed all the plugs and what not. or just put the old crap back in first then seafoam it
  14. Oct 19, 2009 at 12:04 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    X2 on cleaning the throttle body. I did mine recently, big improvement.
    I was told by the dealer & an authorized toyota service center to only change the belt if it is squeeling. Also the water pump doesn't get changed at a set interval. These trucks also have a timing chain that won't need replacing till 250k miles(I think that is what Chris4x4 said on the chain). My 05 truck has 130k miles. I have done all the regular maint. I just replaced the factory battery a month ago(5 year old battery,Wow!).
    No problems so far.
  15. Oct 19, 2009 at 7:14 AM
    cabsav214
    NOR CAL
    08 DC 4x4
    I thought the world standerd auto trans fluid should last the "life of the truck"
  16. Oct 19, 2009 at 8:16 AM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    If the life of the truck is 100,000 miles. Yeah. :rolleyes:
  17. Oct 19, 2009 at 10:45 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    The fuel filter is designed to be a lifetime unit, it's internal to the gas tank. Nigh impossible to change, so I wouldnt worry about it.
    Nice work on the fluids/plugs/driveshaft.
    My '06 SR5 DC is a very similar story. Bought it with 15k miles and did not get a single service record on it. The dealer gave it a thorough inspection before the bumper-to-bumper ran out on it though. I'm not too concerned.
  18. Oct 19, 2009 at 2:11 PM
    george3
    New Jersey
    How often do you need to clean the throttle body. I put Techron in the gas tank every once in awhile. I think that's for fuel injectors, maybe cleaning the throttle body too. Thanks Curious George.
  19. Oct 19, 2009 at 2:28 PM
    DrRabbitFurHead
    Salem, VA
    I'm not sure on required duration but I don't think the gas is going to do much for carbon build up in the TB. I just cleaned the TB on my wife's Sequoia for the first time in 130K miles because the dealership recommended we pay them to do it... :rolleyes: Often times I'll just pay their steep fees because it's easy, but right now that's more $ in my pocket to buy the kids Christmas presents so I figured I'd spend a few hours and clean it and do some other misc maintainance. For the record, it was pretty dirty.
  20. Oct 19, 2009 at 4:32 PM
    george3
    New Jersey
    Thanks. I only have 15000, I guess I'll check it at 30,000.
