2007 blowing smoke at start up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JDB, May 27, 2008.
  1. May 27, 2008 at 10:09 AM
    JDB
    JDB [OP] Member
    07 4x4 off road
    2.5" daystar lift , 18" motometal wheels, custom graphics, custom headlight cover, magnaflow exhaust, kn filter, venture shield clear rocker panels, custom wrap on grill.
    I started my truck this morning and bluish/black smoke came out the exhaust! I thought that I had noticed some a few days ago, but wasn't rally sure. It was only an initial burst, and then no more came out, and none comes out while driving. Does any one have any idea what the hells happening? The truck had sat 3 days over the weekend while I was out of town, before I started it this morning.
    I will take it to my dealer but truth be known, I can't stand the one closest to my house. So it will take a few days for me to get it to another one.
    I have a drop in K&N, and a throttle body spacer is all. I doubt that either one of these would affect anything, but I could be wrong. I have 21,000 miles on it. Also the truck is running better than ever, I'm even getting the best mileage I have gotten since day one.
    How worried should I be?
  2. May 27, 2008 at 10:40 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    If you recently had an oil change check to see if the engine was over filled with oil. A few of us have had it happen.
  3. May 27, 2008 at 10:46 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    +1 Roland-also, on an engine that new-it is usually indicative of oil seeping into a cylinder maybe past a spark plug thru a spark plug hole--maybe they spilled oil in that area OR one of your valve cover gaskets might be leaking down into one. Since you say it only does it on startup that tells me oil (blue smoke) has to collect-but it's something you really have to have the dealer look at:)
  4. May 27, 2008 at 11:57 AM
    JDB
    JDB [OP] Member
    07 4x4 off road
    I have not had my oil changed recently, I guess its a trip to the dealer. I hate going to the dealer.
  5. May 27, 2008 at 12:54 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    its the oil. been there.
  6. May 27, 2008 at 1:30 PM
    TacoinSC
    TacoinSC I'd rather be in Jamaica...
    Greenville, SC
    2011 A.C. 4x4 TRD Off Road
    Undercover
    I know in older cars this used to mean worn valve guides, but in an 07 with 21k...???
  7. May 27, 2008 at 1:47 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    I noticed mine doing it the other day when I first started it. I had been parked on a hill for a few days, so I assumed that had something to do with it.
  8. May 27, 2008 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Very strange, indeed. Im courious as to what the dealer says the problem may be. How is your oil level? It could be your PCV also. :confused:
  9. May 28, 2008 at 4:30 PM
    JDB
    JDB [OP] Member
    07 4x4 off road
    On the phone the dealer said it was condensation and not to worry about it, unless it continues to do it?
    Joe-
    mine was also on a slight hill (my driveway)?
  10. May 28, 2008 at 4:32 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    BLUE AND BLACK smoke aint condensation-SHOOT another do-nuthin friggin dealer:mad:
  11. May 28, 2008 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No kidding. Its not "condensation", its oil. If you have condensation, it will look just like a little steam comming from you pipe. Call another dealer. ALso, call the 800# in your owners manual and tell them that the dealer you spoke with that said its condensation should have all the tools and service idiots removed from the dealer ship.
  12. May 28, 2008 at 7:31 PM
    nc1100c
    nc1100c Active Member
    I noticed my 2008 with only 1600 miles is doing the same thing. It is a dark blue/black smoke only at start up after it has sat for several days. I dont really want to take it to the dealer seems they will tell you anything. Since it is dark blue/black Im wondering if it is excessive fuel where the computer makes the engine rev so high at start up?
  13. May 28, 2008 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Blue/black smoke, I thought, is oil. No?
  14. May 28, 2008 at 7:58 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I am interested in finding out what this turns out to be. please keep us posted.
  15. May 28, 2008 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....Black smoke is Fuel. Blue smoke is oil. Which is it that people are seeing? :confused:
  16. May 28, 2008 at 10:10 PM
    paul gallardo
    paul gallardo rc racer
    northridge, ca
    5lug taco access cab
    fog lights,light bar, sport pedals, tire size swap(from 215/70/15 to 235/75/15to31/10.5/15). Crager 15x8 blackies 2.5 inch lift.Dynomax super turbo, AFE intake system.
    I had a few experiences with toyota motors. They're great but once in a while you'll run into one that has a valve seal leak. What happens is that when the motor sits, some of the oil will seep through the seal and down into the "combustion chamber". Now, when you start the engine up, the oil ignite and burn and out through the exhaust, thus bluish/black smoke. My wife's Camry had it at 42k miles. It's a well maintained car. Dealer should be able to fix it in a jiffy.
  17. May 29, 2008 at 10:33 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    BLUE SMOKE=OIL !! if the smoke is blue your burning oil !! if its white smoke its water ie: coolant or condensation..if its black its fuel not burning.. take it to the dealer..
  18. May 29, 2008 at 2:13 PM
    JDB
    JDB [OP] Member
    07 4x4 off road
    I am in the midst of waiting for my new tailgate to come in to the dealer, I will have them look things over as far as the smoke goes. I'll post what they tell me. To be honest, I have little faith in them, but who knows?
  19. Jun 9, 2008 at 7:15 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    i just noticed my 08 did this this morning. the truck had sat all day yesterday and it let out a big puff of blue smoke when it first fired up. once the cloud went away it was fine... my driveway is slightly at a angle, otherwise when the truck is driven everyday its never done this.
    and i only have 800 miles on mine.
  20. Jun 9, 2008 at 7:38 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    OK you guys NEED to jump on these dealers and find out what the deal is. The ONLY 'smoke' ever to come out of the pipes on my '01 is condensation. Not even a puff of black carbon. You guys have newer trucks here and deserve to have a NON OIL BURNING ENGINE. I dont care HOW the oil is getting into the cylinders-it just is. NOT GOOD. PLEASE keep us posted-I'm dying to hear the excuses coming out of these knuckleheads.
