2007 leaf spring issue
Discussion in 'Suspension' started by Lee, Sep 22, 2012.
  1. Sep 22, 2012 at 9:55 AM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    07 SR5 4 door Tacoma
    I have an 07 crew cab 4x4 with a fiberglass Snugtop shell on the back. The rear leaf springs are so soft that every time I go over a bump, the springs bottom out. Money is tight and I am looking for otions to beef up the rear springs. What is my better option, new rear leaf packs or an add a leaf? The current spring configuration is a 2/1 spring pack. Any thoughts would be helpfull.
  2. Sep 22, 2012 at 10:13 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    AALs tend to be cheaper, but (generally) a new spring pack would last longer.
  3. Sep 22, 2012 at 10:19 AM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    Do you have a brand that you recommend?
  4. Sep 22, 2012 at 9:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, click on the link in my sig.....
  5. Sep 23, 2012 at 2:54 AM
    fpe5
    fpe5 Well-Known Member
    I also have the 07 crew cab with a snugtop and my leafpack was also weak . So i just added the aal and it raised my truck almost 2 inches and it doesn't hit on the bump stops anymore. Worked out just fine for me.
  6. Sep 23, 2012 at 8:33 PM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    What brand did you buy?
  7. Sep 23, 2012 at 8:36 PM
    skeeet
    skeeet Well-Known Member
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    wheeler or toytec AALs are cheap and work well
  8. Sep 23, 2012 at 9:03 PM
    Lee
    Lee [OP] leea1983
    Lee
    Arizona
    Thanks, I will look into it. Did you change out to a longer shock as well?
  9. Sep 23, 2012 at 10:07 PM
    skeeet
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    Nope your stock ones will work :thumbsup:
  10. Sep 24, 2012 at 12:19 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Be sure to torque the leafs down to 73 ft/lbs. I solved most of my rear suspension problems just by doing that.
  11. Sep 24, 2012 at 12:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^If you want to stay at stock height, or close to it, I'd talk to this guy or go with air bags.
    Throwing an AAL into an already tired leaf pack is just a band aid. In a couple years, you'll be looking for another fix.
