2007 Manual Clutch Pedal Creak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigRedToy, Jun 6, 2009.
  1. Jun 6, 2009 at 7:09 PM
    BigRedToy
    BigRedToy [OP] ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    In the past 3 weeks my truck has started the clutch pedal creak or squeak. I took it to the dealership and this is what the work order states "Found slave cylinder squaking on clutch fork when depressed. Lubed Slave cylinder push rod and clutch fork." I think this sounds exactly list the TSB but mine is a 2007.
    Since this is covered by a TSB for 05-06 models. The TSB mentions that the VIN numbers befor 5TE**##*6Z177337 qualify for the TSB. What would be a VIN number befor the one listed?
  2. Apr 4, 2020 at 5:59 PM
    Longtvldan
    Longtvldan Well-Known Member
    Hello i have a 05 and the clutch fork is starting to creak is it covered by toyota?
  3. Apr 4, 2020 at 6:08 PM
    Shellshock
    Iowa
    All you need to do is get some lithium grease and lube up the spring and pivot points
