2007 Rear chrome bumper dent removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icarus II, Aug 13, 2020.
  1. Aug 13, 2020 at 3:50 AM
    Icarus II
    Icarus II [OP] Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Anyone have any experience with this? I hear the metal isn’t real thick. Wondering if it can be straightened.
  2. Aug 13, 2020 at 4:50 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Rockauto sells them fairly cheap. Easier to just replace. Just be prepared to deal with rusted bolts that would likely break.
    They are really thin, they can actually be twisted.
  3. Aug 13, 2020 at 4:52 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Bring it to a body shop and see what they say.
  4. Aug 16, 2020 at 4:18 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Thanks, All.
  5. Aug 16, 2020 at 5:08 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I had a small dent in mine and two local PDR guys both said they wouldn't touch it. As thin as Tacoma rear bumpers are, apparently they're too thick to use the paintless dent repair process on. I ended up getting a used one.
    BTW, Beware aftermarket bumpers. If you think the OEM stuff is thin, many of the aftermarket ones are like aluminum foil. And if you go for chrome plated, their plating absolutely stinks.
    cruxofthebisquit likes this.
  6. Aug 16, 2020 at 5:25 PM
    Muddinfun
    Muddinfun Well-Known Member
    A 4lb hammer and a 2' long 2"X4" will get most of a dent out, but the bumper has to be off the truck. Have a friend hold the end up with the dented part on soft dirt. Pound away at the dent. If the whole shape of the bumper is bent, that takes some creative winching with the bumper on the truck and you won't get it to fit perfect. I've straightened a few. They didn't come out perfect, but they were vastly improved.
  7. Aug 18, 2020 at 8:44 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    It can certainly be straightened, but the chrome will most likely crack. At that point you'll have to sand and paint it.
  8. Aug 19, 2020 at 10:31 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    I definitely wouldn't say our bumpers are thin...wait till you take it off! The Bumper is stamped from some pretty thick steel and then plated. Anything you do to work the dent out will result in damaging the plating most likely causing it to flake off eventually if not instantly. Getting a new OE one on Ebay, there cheap and mine has been looking great for the last 3+ years.
    https://www.ebay.com/itm/NEW-Steel-...Tacoma-05-15-SR5/282709319473?epid=1079807028
