2007 Taco - ABS/Brake light on, no reason?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Feb 16, 2010.
  1. Feb 16, 2010 at 9:32 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Was driving down the road at around 35mph when I noticed my brake light and ABS light were shining red. I pulled over, checked the parking brake, it was fine. I drove a little, tested normal braking, seemed all fine. What type of error is this?
    attached an image.
  2. Feb 16, 2010 at 9:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Check your brake fluid level and fuse for ABS.
  3. Feb 16, 2010 at 9:40 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    x2 check your brake fluid level.
  4. Feb 16, 2010 at 12:11 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    The fluid is full, fuse is fine. The lights go off if the vehicle sits for awhile, when I drive it around and it warms up, the lights turn on.
  5. Feb 16, 2010 at 12:21 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    It could be one of the wheel sensors went bad, or a problem with the skid control ECU. I read in the owners manual that if the ABS system detects a fault within the system it disables itself for safety sake.
  6. Feb 16, 2010 at 12:24 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Stealership here I come
  7. Feb 16, 2010 at 12:26 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I wish I could tell you more about the wheel sensors. I know some guys unplug one sensor when they wheel their trucks to disable the ABS when they offroad. A simple visual inspection may be helpful.
    EDIT: I found a diagram which may help you. This is for the 2009 model, but it's probably the same for your truck too.
    EDIT: I found a diagnostic procedure see links below.
    Component locations: Here's the factory diag procedure:
    Brie and MuddyJackson like this.
  8. Mar 28, 2011 at 11:33 PM
    Drabbit17
    Drabbit17 Active Member
    Diego
    Costa rica
    05 sr5 access cab
    Hello all. I got my fist Tacoma im from costa rica and I bought it in the states. The abs and the break lights are always on. Could you guys help me out with this. Does someone know what could it be??
    Also the car didn't bring the owners manual, does someone knows from where can I find it??
  9. May 23, 2012 at 11:50 PM
    imprezzivesti
    imprezzivesti Member
    you ever fin a solution to this?
    Also for those of you who did the ABS wheel sensor switch mod to disable ABS do your lights stay on even when the switch is allowing the wheel sensor to operate?
  10. Nov 12, 2012 at 6:37 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Anyone find a solution? My 06 has the same problem, haven't checked the fluids yet will do tomorrow!
    Thanks!
  11. Nov 13, 2012 at 5:03 AM
    Drabbit17
    Diego
    Costa rica
    05 sr5 access cab
    Check if the sensors are pluged in. The problem in my truck was that one of the cables was cut so I just fix it then disconect the battery to reset de computer and the light was gone.
  12. Nov 13, 2012 at 5:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had the same problem a few months back but it turned out to be the brake fluid was low. It was still within the min-max limits, but on the lower end. Filled it up to the max line and the light went off.
  13. Nov 13, 2012 at 6:19 AM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    Does your SR5 have a locking rear diff? I'm not familiar enough with the options to know.
    This is a bit of a recurring issue for the sensor that indicates if the rear diff is locked or not. It either fails or gets gummed up and sends a false signal. Normally when you lock the rear diff the ABS gets disabled automatically and the warning light comes on. The remedy is to clean or replace the sensor and it's a trivial task, screw out, clean, screw back in.
    If you don't have a locking diff, then its probably fluid levels or electrical as the others have suggested.
  14. Nov 13, 2012 at 6:23 AM
    Pugga
    Massachusetts
    Unless it's a custom option, I don't believe the SR5 was ever offered with a locking rear differential. The mechanical limited slip was an option in certain years up to 2008 but never the locker. That is specific to the TRD Off Road package. It looks like the OP has an off road so that could be his issue, but for anyone else reading with just the basic SR5, that is not your problem.
    Brie likes this.
  15. Apr 2, 2015 at 12:04 AM
    MAUIxROCKSTAR
    MAUIxROCKSTAR Well-Known Member
    Maui, Hawaii
    2015 VOODOO BLUE TACOMA
    Did anyone find anything else to finding a solution to this and problem? I have a friend with an 08 and same thing ABS turns on at 35mph after resetting the abs light by jumping pin 4 and 13.
    Brie likes this.
  16. Mar 14, 2016 at 3:55 PM
    SurfnSwdsman
    SurfnSwdsman Member
    2007 Tacoma V6 TRD Off Road 4X4
    Any definitive solution to this problem? My truck just started having the same issue yesterday. Mine is a 2007 TRD offroad SR5 4x4 with rear diff lock. I checked the brake fluid and filled it up a bit, it wasn't that low.
  17. Mar 14, 2016 at 4:38 PM
    SurfnSwdsman
    SurfnSwdsman Member
    Found this shortly after. It sucks 2007 is on that list.
    "Sensor on Toyota Tacoma
    At higher mileages, an anti-lock brake system wheel speed sensor may wear out and illuminate the ABS warning light. It is recommended to replace the sensor with a factory part and be sure to clean all rust and debris from the mounting area because the mounting distance is critical. Failure to do so may result in the new sensor setting false trouble codes. Be sure to check the condition and runout of the front wheel bearings on the 2WD and 4WD vehicles and the CV joints on the 4WD vehicles since worn wheel bearings and/or CV joints can cause the ABS trigger rings to rub against the ABS sensors and damage them.
    RepairPal Verified
    Average mileage: 102,500 (102,000–103,000)
    5 model years affected: 1995, 1996, 1997, 2002, 2007"
    Brie and pats73 like this.
  18. Mar 14, 2016 at 7:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    To be honest about this, it isn't just those year models and it isn't a defect. What they are describing is called normal wear and tear and it could happen to any year model vehicle with higher mileage.
  19. Mar 15, 2016 at 1:02 PM
    SurfnSwdsman
    SurfnSwdsman Member
    Never said it was a defect. Normal wear and tear for sure, unfortunately that it happened to my 2007. I filled up the brake fluid to full and so far so good, no ABS light. Knock on wood. Will see how long that lasts.
  20. Mar 15, 2016 at 1:03 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    A lot of times the ABS sensor, which is magnetic, gets covered with metal filings and just needs cleaned off.
    Brie, pats73 and HBMurphy like this.
