2007 Tacoma SR5 4x4 158k Shuddering and "rumble strip" vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Auto_Drum, Apr 13, 2017.
  1. Apr 13, 2017 at 8:21 PM
    Auto_Drum
    Auto_Drum [OP] Member
    Austin
    2007 Tacoma SR5 Access Cab
    33" BF Goodrich Baja Champion All Terrain tires with 16" Procomp wheels
    Welp my truck is in the shop for the 4th day...so frustrating. The problem seems to only occur around 20 to 35 mph and mostly when I'm accelerating up inclines. It isn't a constant, it happens at very random times. It can be a hard shake or it can feel and sound like I'm driving over a rumble strip. When the shuddering or vibration occurs it instantly goes away when I let off the gas or move the shifter to "4". I'm having the cv replaced and the needle bearing inspected tomorrow...anyone else experience this????
  2. Apr 13, 2017 at 8:30 PM
    jamsandwich
    jamsandwich Ski Bum
    Teton Village, Wyoming
    09 DCSB TRD OR 6spd
    sounds like a driveline issue... u joints look ok?
    Jimmyh likes this.
  3. Apr 13, 2017 at 8:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Looks like trip to the auto parts store for u joints and carrier bearing. Good luck and Rock and roll!
  4. Apr 14, 2017 at 8:57 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    Vibrations are a sore subject for me, but I can give some tips.
    In order of cheapest/easiest:
    1. Put some spacers under your carrier bearing to try and bring the driveline angles into spec.
    2. Replace u-joints (and carrier bearing too while you're down there).
    3. Check into the East Coast Gear Supply (needle bearing) diagnosis/fix.
    4. Get driveshaft rebalanced.
  5. Apr 14, 2017 at 9:22 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    if worse when cold, it might be tranny fluid is low
    Auto_Drum[OP] likes this.
  6. Jul 20, 2017 at 4:02 PM
    6Toys
    6Toys Member
    Scott
    2nd gen. 2005 Tacoma TRD
    I've just encountered the same problem with my 2005 Tacoma 4x4 TRD. Gets more pronounced as the vehicle warms up. Does it in "Drive", but does NOT do it in "4". My Toyota mechanic in eliminating u-joints, tranny talked with dealership service and the question of computer came up. Have any others been down the road of it being a computer issue with this seemingly common problem? Apparently this might be the case with 4 cylinder models, but I've not done the research to confirm. Anymore insights on the "shaking under low speed acceleration" issues other than what is covered above and in other threads? Thanks-
  7. Jul 20, 2017 at 5:09 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    My truck did the same thing. Torque converter.
  8. Jul 20, 2017 at 6:04 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I would agree with bebop on it being the torque converter. If its not locking up then it will give a shudder type feel to the vehicle. Once put into another gear it locks up and vibes go away until it starts slipping again. I could be wrong but don't over look it if it's not fixed buy drive line adjustments and or c.v. repairs
    Bebop likes this.
  9. Jul 20, 2017 at 6:13 PM
    Bebop
    Nick
    Now that I have more time to type here is what happened to mine. Under light throttle after it got hot usually about 30mph the whole truck would shutter or give the rumble strip feel. If I slammed the throttle down or got on the brakes or popped it in neutral it would go away. Took it to the Monkeys at joe Meyers Toyota. They told me to turn my radio up. Truck only had 50k on it. Drove out to fort bend Toyota and let them look at it and they tried to say it was my tires. Wrong. Got the service manager involved. Told him I was pretty sure it was the torque converter. I took him for a ride and got it to act up and he was shocked at what the truck did. He said he's only seen this in tundras. They kept the truck for warranty repairs and gave me a hot shit corrolla rental car for a week. Fixed the problem.
    desertrunner24 likes this.
  10. Jul 20, 2017 at 7:41 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Yup torque converter. Drain and flush old WS with Maxlife and add some Lubegard Platinum following their instructions. Bet money no more shutter.
    Read up on some of Gearcrunchers post. Very informative.
  11. Jul 21, 2017 at 1:51 PM
    CoastalComa
    CoastalComa Well-Known Member
    Mendocino
    '08 6spd sr5 Sport
    I put my lift on, and it started vibrating at about 35-45mph. Found u joints were worn out, mostly the one at the rear axle. I replaced them and it was still vibrating. Took it to a shop to check the driveline, they found that one of the wheel weighs fell off. Usually if it's u joints or bad driveline, the vibration doesn't smooth out with higher speeds.
  12. Jul 21, 2017 at 7:57 PM
    Lthompson
    Lthompson Well-Known Member
    how violent is this "rumble strip" vibration I read about.. I have a vibe, But its not in between gears, or during shifting. Its all right around 1800 to 2300 rpm, in any gear. Whether I'm goin 20, 40, or 60. Its all related to the rpms I'm at and load. don't have a clue. Everyone tells me I just have to deal with it. Trans shop, and the dealer. Its very annoying. Even drones out, and I hear it OVER the radio. Felt everywhere. In the seat, in the steering, in the peddles.
  13. Jul 24, 2017 at 7:03 PM
    CoastalComa
    Mendocino
    '08 6spd sr5 Sport
    Does it happen at those RPMs in neutral? Have you had your engine looked at? Any dash lights on?
  14. Jul 24, 2017 at 7:58 PM
    Lthompson
    No vibes I can tell in neutral. Only under load at mentioned rpm. No lights. No other issues.
  15. Jul 30, 2017 at 1:00 PM
    oldmanbrown2011
    oldmanbrown2011 New Member
    Ryley
    2011 Tacoma SR5
    i just purchased my 2011 Sr5, i am having the same type of vibrations, brought it to the dealer and they did the following;
    1. checked the transmission fluid..... it was good and where it should be.
    2. took the drive shafts off and inspected everything, nothing was out of order and they were all recently replaced....
    3. swapped my tires for a new tacoma rims and tires just to try it, and they said it fixed it... but i never got to try it for myself......
    i want to believe them, but i also dont want to go buy new tires... just bought the truck boys, its bugging me....
    with my old tires on, it still, not all the time, but more often then not will vibrate like you guys are saying around 50 kmh and 60....
    i have 30 days to return it... but i really dont want to if i can get this figured out.... is there any good ways to check and see if the torque converter is getting bad.....
  16. Jul 30, 2017 at 1:56 PM
    Bebop
    Nick
    The torque converter is a sealed unit bolted to the engine that sits inside the transmission bell housing. It's not a part that can be physically inspected.
  17. Jul 30, 2017 at 4:37 PM
    oldmanbrown2011
    Ryley
    2011 Tacoma SR5
    so in other words... go with my gut, take it to toyota, take the tech for a drive to confirm it... then see if where i bought it from will replace it, or send it back..
    on that note
    would you recommend just replacing the transmission or just the torque converter
  18. Jul 30, 2017 at 5:33 PM
    Bebop
    Nick
    You don't have to replace the transmission if the torque converter is the problem like mine was. But the transmission does have to be removed to access it.
  19. Jul 30, 2017 at 7:40 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Could be the fluid is degraded to the point to where the friction modifier isn't doing its job anymore. Has it ever been changed?
  20. Jul 30, 2017 at 9:03 PM
    Lthompson
    make em swap the wheels and tires and let YOU verify if that it fixes it. Would not take their word for it
