2007 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tradedave, Feb 8, 2012.
  1. Feb 8, 2012 at 3:03 PM
    Tradedave
    Tradedave [OP] New Member
    Hi, I am looking at buying a used 2007 Tacoma double cab, model # is 7596c. Looks to be in great shape. Can anyone tell me their thoughts. I have never owned a Toyota before, much less a pick up. It has 46000 miles and the dealer wants $23000. Any thoughts. It is automatic heavy tow package. Let me know questions if you have them.
    What are your thoughts on this vs a 2008 FJ?
  2. Feb 8, 2012 at 3:16 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    We'll need more details than "model #7596c".
  3. Feb 8, 2012 at 3:21 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Sorry, but 7596c is not a model number.
  4. Feb 8, 2012 at 3:28 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yeah prob. a dealer code of some sort
  5. Feb 8, 2012 at 3:45 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I bought my 2007 Tacoma in 2010 for 16.5 from a dealer. It is an access cab base model, 4cyl. and 5 sp. and had 40,000 miles on it. Not anything fancy,but does fine for what I need, and at a reasonable price.
  6. Feb 8, 2012 at 5:20 PM
    Tradedave
    Sorry that is what the dealer gave me. It is a double cab v6 long bed. 4 wd with heavy duty towing package. SR5 package #2. Hevy duty battery. Don't know what else I can tell you.
  7. Feb 8, 2012 at 5:28 PM
    acdronin
    acdronin Well-Known Member
    Welcome to TW Dave, I bought mine with 28k on it for 25,000, since then it has been to Idaho twice and to Seattle once it now has 92k on it, i have worked and played in this truck and it's part of me. I have had ZERO mechanical issues and have only had to upgrade the suspension because the stock rear leafs are weak. I change the oil (synthetic only), every 4k, I am on my second set of plugs, second set of front brake pads, i have changed the differentials and transfer case fluids once so far and drained and refilled the tranny using toyota atf fluid. This is BY FAR, the best vehicle I have ever owned. Not crazy about the MPG's but hey, it's a truck, a very capable truck.
  8. Feb 8, 2012 at 5:43 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    I got an 07 4x4 DC with about 50k on the clock. Got it used with a few scratches here and there so I don't have to worry about it being pretty! But it runs great. W/o knowing all the details, that sounds like a decent deal. The 07 still has the mechanical limited slip, but doesn't have all the array of technology "improvements" that newer models have.
  9. Feb 8, 2012 at 7:31 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    What exactly are you refereeing to? In the market for a tacoma, and am curious about the differences you are talking about.
  10. Feb 9, 2012 at 2:55 PM
    Tradedave
    (I understand this is a Tacoma forum, but), Any oughts about he Tacoma vs FJ?
  11. Feb 9, 2012 at 4:10 PM
    acdronin
    the later tacomas have back up cameras, A-TRAC (some fancy gizmo for bad condidtions) and a few other things, meh? Don't need it.
    Your model that you are looking at, is it a TRD? IF so, is it a Sport or an Off Road?
  12. Feb 10, 2012 at 5:30 AM
    SpeedoJosh
    Florida
    I'm looking at TRD Off-roads. Not sure about the OP though
  13. Feb 10, 2012 at 5:37 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    That may be a bit steep for a 2007. See if its a Off Road package or Sport package or just plain SR5. I does effect the value somewhat. It will say on the bed of truck which package.
