2007 V6 4.0 liter oil change help
Discussion in 'Technical Chat' started by ronmdon, Sep 20, 2010.
  1. Sep 20, 2010 at 9:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Make sure you use the correct fluid in the tranny also.
  2. Sep 20, 2010 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Consider this a last warning to shape up, and fly straight. OR ELSE!! :cool: (serioz look, but cant think of a "or else")
  3. Sep 20, 2010 at 9:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One more screw up, and IM BANNING HIM!!!
    *points to 98tacoma27*
  4. Sep 20, 2010 at 9:45 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    quick glance I'm not seeing the fill tube for tranny fluid...
    best to ask for the correct thread on that.
  5. Sep 20, 2010 at 9:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is no Fill tube. Its a sealed unit. There is a Fill plug about halfway up the side of the tranny. It will look like the fill plug on the rear diff.
  6. Sep 20, 2010 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This will help:
  7. Sep 20, 2010 at 9:49 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    ^^^ Best Thread ever. Worth the time to read.
    Definitely change the oil again. Eat the cost of the oil you put in it, drain ALL of the oil and start over.
    For those advising him to just re-fill the Tranny fluid he drained... Isn't it a sealed tranny? Shouldn't he have to tow the truck to the dealership and have it done there?
    Good luck to you, buddy. Your story should be a warning to all... READ and MAKE SURE first! It's a PITA if you don't.
  8. Sep 20, 2010 at 9:49 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah...no kidding. But that idea makes so much sense they won't do it. lol
    I guess if they do put on a sticker, they'll end up with less people showing up at the service departments giving out their hard earned money to them.
  9. Sep 20, 2010 at 9:50 AM
    mws4ua
    Birmingham
    Clearly I took to long to write my previous response... I should have known Chris would be all over it.
    Sad, but I bet that's exactly the reason they don't make it more clear. SURELY they've heard complaints from Do-It-Yourselfers over the years, but the don't make it any more obvious.
  10. Sep 20, 2010 at 9:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If I were you, I'd refill the tranny, run it for a little while and change the fluid out again. If there are any metal shavings from running it without fluid, I would think you'd want to flush them out as much as possible. May be a waste of money but that's what I'd do if it were my truck.
    OP, a little story to make you feel better, my cousin drained his oil put the fill plug back in, went in to grab lunch, got sidetracked and went out for a drive a few hours later. Ended up costing him $4,000 for a Jasper engine.
  11. Sep 20, 2010 at 9:56 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Lookit the oily spots around the allen socket plug...wonderin' if he 'drained' the tranny fluid check port?? In which case nothing done to the tranny.
    Just a guess.
    But what about overfilling the engine oil to the tune of 5qts....hmmm
  12. Sep 20, 2010 at 9:57 AM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    Lets hope for the best OP.
    Yup we were noobs once. Larry has a point though. Read, research, read and research, heck before I did my first oil change I drilled the whole thing well into my head. I printed the DIY oil change and had it with me during the procedure. If I had doubts, I stop and ask TW. In our gun club we had this belief: Its better to ask a stupid question than commit a stupid mistake.
    OP is man enough to : 1. Do oil change himself
    2. Admit his mistake sought advice.
  13. Sep 20, 2010 at 9:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. If only a quart or so came out of the tranny, no harm should be done. Over filling the engine by 5 quarts is a bad thing though...
  14. Sep 20, 2010 at 10:00 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    the total amount of tranny fluid that came out was about 1.3 liters.
    being the genius that I clearly am with auto-mechanics, i drained the final .3 liters last night thinking I was still draining the overfilled oil.
    So, the tranny was not totally dry for the drive....
    I'm draining the REAL oil pan now.
  15. Sep 20, 2010 at 10:11 AM
    #35
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Very true. best of luck OP
  16. Sep 20, 2010 at 10:24 AM
    #36
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    recap:
    -drained 1.3 liters out of tranny overflow plug
    -drained 9 qrts of oil out of the overfilled oil pan.
    Will refill engine oil with 5-6 qrts (will start with 5 and go from there)
    Will refill tranny fluid with 1.3 liters of Toyota WS ATF fluid
    If damage is done, am I looking at busted seals, new trany, engine, truck, and busted checkbook..?
  17. Sep 20, 2010 at 10:28 AM
    #37
    98tacoma27
    Ben
    Not Beech Creek
    WTF!?!?! I did nothing but help!!! Powa hungree Mod anywho!!
    You hush. I am on Boyds side with this one. BAN LURRY!!!
  18. Sep 20, 2010 at 10:30 AM
    #38
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Oh snap 30 miles with a drained transmission.
  19. Sep 20, 2010 at 10:33 AM
    #39
    98tacoma27
    Ben
    Not Beech Creek
    Not fully drained.
  20. Sep 20, 2010 at 10:38 AM
    #40
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    So look at this: It appears I only drained out about 1/4 of the tranny fluid, so not a true dry tranny.
    Main issue I suppose would be the 9 quarts of oil in the engine...
