2008-2012 backup camera work on a 2014?
Discussion in 'Technical Chat' started by LimblessJack, Nov 11, 2013.
  1. Nov 11, 2013 at 6:01 PM
    LimblessJack
    LimblessJack [OP] Member
    Norcal
    2014 MT Tacoma
    Hey,
    Anyone know if a 2008-12 backup camera hook straight up to a 2014? Didn't feel like pulling the tailgate apart to see,
    Thanks!
  2. Nov 15, 2013 at 12:00 AM
    LimblessJack
    Norcal
    2014 MT Tacoma
    Well can anyone at least tell me what the part number would be for the backup camera in a 2013?
  3. Nov 22, 2013 at 6:34 PM
    yogster
    yogster merkwürdigliebe
    Tom
    Massachusetts
    13 Black DCLB SR5
    DCLB Black 4WD Illumination dial from 4runner, Flyzeyes LED. Hardwire GPS and Valentine1 with BlendMount mirror mount, TRD shift knob, tube steps, swapped out for signal lamp mirrors. Garmin Eco-Route HD for Bluetooth ODBII Diagnostics, 2014 Entune Plus w Navigation, Leer 100XL dome light wired to dome circuit, pop&lock tailgate and cap locks.
    Hmmm, here's some information you might find useful
    1. I have a 2013 double cab long bed. It came with a backup camera and displayed the image with guidelines in the rear view mirror. The guidelines are part of the mirror display, I confirmed this.
    2. I swapped my 2013 "Display Audio" for a 2014 Entune Premium Nav Unit. It was plug and play.
    3. I purchased the mod to move the display from the mirror to the radio. This was easy. Video now displays on radio. HOWEVER, guidelines do not. I would have thought that the guidelines were part of the radio display for 2014s. This appears not to be the case.
    This would mean that installing a 2013 or earlier camera would not show the guidelines on your system. Of course maybe different 2014 radio models behave differently.
    Also the cameras are OUTRAGEOUS expensive direct from Toyota- $800. Seriously. There's at least one person selling compatible cameras (With the correct bracket) on ebay for about 1/8 of that. Jemko is another source.
    Lastly, Pop&Lock had to modify their manual tailgate lock accessories because of a change to the backup camera on the Tacoma in 2014. I don't know if the change would also mean retrofitting a camera from 2013 would be a problem too. The 2014 part numbers are not available to compare.
    Here is the part number through 2013, appears to be unchanged for all years that support a camera up to 2013 86790-04010. Actually, I was a little off. Price is *only* $630!!!
  4. Nov 24, 2013 at 11:36 PM
    LimblessJack
    Norcal
    2014 MT Tacoma
    Hmmm that's a lot of helpful info. Thanks, I guess I might have to wait till more info comes out or just rip open my tailgate and see what kind of connection is in there.
  5. Dec 16, 2013 at 6:43 PM
    nimrod1
    nimrod1 Member
    the 2008-2013 toyota backup camera will work in the 2014 tacoma but you will need to purchase the 2008-2013 tailgate harness as well because the 2014 tailgate harness is different at the camera end, not the bumper connection end.
  6. May 14, 2014 at 7:38 AM
    MidwestGreen
    MidwestGreen Member
    This was successfully done in this thread: http://www.tacomaworld.com/forum/2nd-gen-tacomas/325991-2014-backup-camera-2.html#post8654980
    There are also two types of cameras, the newer version and the older version. If you check the tailgate harness at the camera end, you can immediately tell if it is a four or six prong.
    Note that the older version, 86790-04010, which I know works in an 09, has four prongs in the harness connector, and it has five little slots all the way around the harness perimeter.
    The newer version, 86790-04020, which was successfully used on this board in a plug an play works on a 2014. This harness connector has 6 prongs, and more of a bottom clip.
    Pictures of the two cameras can be found here: http://www.tacomaworld.com/forum/2nd-gen-tacomas/325991-2014-backup-camera-2.html#post8586981
  7. Dec 13, 2016 at 4:58 PM
    jsemog
    jsemog Active Member
    Junior
    brockton ma
    SR5 4x4
    hi i had the entune head unit with the backup camera but i change it to ipad
    i bought the rear view mirror that hce the bacup camera i plugged in but its not displaying the camera
    can anyone help me make it work pls???
