2008 Guardian Factory Alarm? I NEED silent arming help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bobby, Aug 12, 2008.
  1. Aug 12, 2008 at 12:00 PM
    Bobby
    Bobby [OP] Member
    So Cal
    08 PreRunner TRD
    Hello,
    I just got my truck and I got the dealer alarm. Its a guardian G1. I'm trying to figure out how to turn off the 2 horn honks every time I lock it. Its really annoying especially since I come home late at night often.
    Anyone know about this alarm. So far I've searched and only found references to other types of alarms that are different to program.
    Thanks
    *Update*
    I found the installation instructions. Just in case anyone ever searches and needs this here's some info:
    The alarm is a Guardian CPL 100. This was the alarm installed at the dealer (Power Toyota in Cerritos, CA). The website for this alarm company is http://techservices.codesystems.com
    To program the alarm do this:
    1. Turn ignition on
    2. Press and hold override button
    3. Within 10 sec the system will chirp 3 times
    4. Press override button again, 4 chirps should be heard indicating its in programming mode
    5. Now get your keys and each time you press the red panic button it takes you to a different programming option
    6. Pressing the panic button 7 times brings you to the Chirps option. You should hear 7 chirps and the override LED should flash once indicating its in the default state for the chirp option (ON)
    7. To turn chirps OFF you must press the remotes LOCK button. The override LED should flash 2 to indicate that chirps are OFF now
    8. Exit programming mode by turning ignition OFF
  2. Aug 12, 2008 at 3:24 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    many alarms default is hitting both lock and unlock to change to silent arm/disarm.
    if that doesn't work Hold the arm button down.. and sometimes that also works.
    I also looked up gaurdian and found nothing... not even a home page for a company called gaurdian that does auto alarms.
  3. Aug 12, 2008 at 3:34 PM
    mudslingin44
    mudslingin44 Well-Known Member
    west palm beach, fl
    07 tacoma double cab trd 4x4
    6 in pro comp coilover-35 in pro comp extreme mudders
    what does the remote look like? how many buttons.try hitting the #2 button before the#1 button if it is a 2 button remote
  4. Aug 12, 2008 at 3:54 PM
    Johnson8537
    Oregon
  5. Aug 12, 2008 at 4:58 PM
    Bobby
    Bobby [OP] Member
    So Cal
    08 PreRunner TRD
    It was installed/activated at dealership when I bought the truck. But its not the VIP RS model I'm pretty sure.
    The key fob is black with toyota symbol on back. It has three buttons, two large lock/unlock and the small red panic/hold button.
    There is a led light and switch mounted under the dash too that I'm sure is part of alarm.
  6. Aug 24, 2008 at 9:21 PM
    Bobby
    Bobby [OP] Member
    So Cal
    08 PreRunner TRD
    I found how to program the alarm and updated the original post for future reference.
  7. Dec 4, 2009 at 8:05 PM
    etjatm
    etjatm New Member
    College Station, TX
    '08 PreRunner SR5
    Hi...any clue if the system will automatically lock the doors after starting or when put into drive? If each press on the red panic button it takes you to a different programming option, what are those options? I've tried your link but can't find anything. Thanks.
  8. Jul 22, 2010 at 4:46 PM
    JustLivinHakeem
    JustLivinHakeem New Member
    I have the same Guardian CPL 100 system on my 2009 Camry from Power Toyota Cerritos. The back of the keyless entry transmitter says "CPL-100TX" and "FCC ID: H5OT21".
    The best way to find support for this system is to call the manufacturer Code Systems at 800.421.3209 (number engraved on transmitter) and you will get a service representative who can send you the instructions you need. You can also email them at support@codesystems.com. Their website is not fully functional at the time of this posting.
    When I called them I asked them to send me the "programming feature bank options" and they ended up sending me the "CPL 100 Installation Instructions" Manual which I attached.
    The instructions that Bobby gave are correct for turning off the chirps (option 7). The other programming functions are (with options in parenthesis):
    1. Security Function (On, Off)
    2. Passive Locks (Passive, Active)
    3. Silent Choice (On, Off)
    4. Passive/Active Arming (Passive, Active)
    5. Siren/Horn (Siren, Horn)
    6. Door Trigger Delay (Instant, 30 sec.)
    7. Chirps (On, Off)
    8. Extended Locks (0.9 sec, 3 sec, Dbl Pulse U/L)
    9. Ignition Controlled Locks (On, Off)
    10. Tan Wire Output (Trunk, 2nd Unlock, Illum. Entry, ITS Function)
    11. Unlock Switch Sense (NEG, POS)
    12. Horn Output Timing (16mS, 40mS, 72mS)
    13. 2nd Step Unlock (On, Off)
    I'm not sure what some of these mean, but the Code Systems representative should be able to help.
    Manuals posted online can be found at: http://auto.manualsonline.com/ex/thread/view/idThread/368277
  9. Sep 5, 2010 at 10:51 AM
    etjatm
    etjatm New Member
    College Station, TX
    '08 PreRunner SR5
    Thanks for the help! I'll try contacting them.
  10. Sep 8, 2010 at 3:36 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    THANK YOU!!!!!!! the dealership that I got my Taco from also did the same thing and it's bugging me since they pretty much left the old alarm installed (found the horn and the door actuators today, BIG HELP that you got the diagram for the alarm. :D ) thank you again.
    229C1077-5D18-9F00-79BF-20EABD5DA9F6
    1.03.01
  11. Sep 8, 2010 at 4:15 PM
    07TacoRidah
    ok problem, I have an aftermarket siren, I want to use that instead of the horn, anyone know how to hook that one up? I hooked it up to the blck/brn wire and nothing. It worked for my horn.
    1.03.01
  12. Jul 24, 2011 at 6:29 PM
    aboutpar
    aboutpar New Member
    phil
    New Mexico
    The override button???? Thanks
  13. Jul 24, 2011 at 10:24 PM
    JustLivinHakeem
    The "override button" is located on the backside of the component with the red flashing light. In my instance, this was mounted below the dash underneath the steering wheel. If you feel behind the light, you will notice the button you can press in. Hope that helps.
  14. Aug 4, 2012 at 3:59 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    I know this is a old thread but previously I was able to turn off the horn with these instructions. I just replaced my trucks battery and now the alarm auto arms itself and I tried re-programming but it wont go into programming mode. Any ideas? Thanks
  15. Aug 6, 2012 at 2:32 PM
    othater
    SoCal-Walnut
    bttt..
    Truck was originally from Longo Toyota, El Monte. Purchased used a few years back.
    I also noticed the led does not flash when armed.
    Either solid led when armed or led off.
  16. Aug 7, 2012 at 2:06 AM
    JustLivinHakeem
    Not completely sure why it "won't go into programming mode" but I would troubleshoot by trying options in the Manual attached earlier in this thread:
    (#1 - Toggle Selections in Programming Bank)
    Double check that you can't enter into Programming Bank 2 (4 chirps) at all using the specific instructions from the Manual. If you can, try toggling each Selection in the Programming Bank using your best judgment to see if you get the desired results (even the manual doesn't describe the possible selections very well).
    (#2- Default the Programming Bank)
    Try Defaulting the Features in Programming Bank 2
    1. Turn the ignition ON.
    2. Press and hold the override button.
    3. Within 10 seconds the system will chirp (3) three times.
    4. Press the programming button on the module, the system will chirp (4) four times indicating the features have been defaulted and is now in feature programming bank 2.
    ....Perhaps this will clear the system and then you can go back and change the specific features you want again (like Chirp Off).
    (#3 - Contact Manufacturer Support)
    Perhaps your Unit got switched from "Consumer Mode" to "Lot Mode" in which case an "ACM keypad" is needed. Seemingly this would require professional assistance... but before that I would try calling the manufacturer Code Systems at 800.421.3209 to see if a service representative can assist you. You can also email them at support@codesystems.com.
    Hopefully, that pushes you in the right direction.
