2008 rear dif lube question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rocketman1, Mar 2, 2014.
  1. Mar 2, 2014 at 12:18 PM
    rocketman1
    rocketman1 [OP] New Member
    Florida
    2008 & 2009 Tacos
    Greetings folks! Prep-ing to do fluid changes in my 2008 4X4 Tacoma SR5. Label on dif states "LSD oil only". Manual states to use SAE 90 LSD API GL-5 lube. Haven't been able to find straight 90 at any of my local auto parts stores. My question is, before I make the over an hour drive to the nearest Toyota dealership and hock my first-born to buy their 90 w lube, is there any other lube alternative for me to use? I am not adverse to using straight synths as I've run Mobil 1 oil in all my Toyota trucks since 1987 (still wish I had that one!) with very good results. Keep in mind that I'm in Central Florida and the temp here in the summer is brutal.....(My 2009 Taco is just so much easier as far as F/R dif and transfer case lube rqmts.!) Thanks in advance for the advice and/or recommendations.
  2. Mar 2, 2014 at 12:22 PM
    landphil
    landphil Mynd you, moose bites Kan be pretti nasti…
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    75w90 with a bottle of LSD additive will be perfect.
  3. Mar 2, 2014 at 12:37 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    A 75-90 is fine. Make sure it has the LS additive.
    You can still get Mobile 1 LS. I get mine on Amazon for $12 and its a 75w-90 with the limited slip additive. Have it in both my transfer case, and both front and rear diffs on my 07 since forever (about 2009). I highly recommend it!
    I've also heard good things about Amsoil "Redline" 75-90 gear oil. You'd have t add the LS additive yourself.
  4. Mar 2, 2014 at 2:22 PM
    rocketman1
    Florida
    2008 & 2009 Tacos
    Thanks again for the advice guys!
  5. Mar 2, 2014 at 2:46 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    The only way to ensure you won't get chatter is to fill the LSD with 80W-90 dino and a tube of this:
