2008 speaker wire colors
Discussion in 'Audio & Video' started by Tacotwo, Jun 2, 2009.
  1. Jun 2, 2009 at 5:49 PM
    Tacotwo
    Tacotwo [OP] Active Member
    Hey everyone, im gonna be installing some new speakers this weekend and wanted to double check on this. Did some searching and found the wiring diagram for a 2007, mine is a 2008 DC and was wondering if it was the same.
    Thanks,
    Scott
    LF (+) pink
    LF (-) violet
    RF (+) blue
    RF (-) light green
    LR (+) black
    LR (-) yellow
    RR (+) red
    RR (-) white
  2. Jul 24, 2010 at 6:19 PM
    xjake
    xjake Member
    Santa Cruz, CA
    2010 Access Cab 2WD
    Just wanted to say that the diagram listed above appears to be true for my 2010 access cab Tacoma with base stereo. I tapped into the rear speaker wires at the head unit and added rear speakers to the access doors. I got the speakers from Tacotunes. MDF plate matched up to the holes, but I needed nuts and washers as there were not threaded holes to mount to. Still not sure what to do about the lack of an opening in the door panel, for now I just cut a hole, but will probably try and apply speaker fabric over the hole.
  3. Mar 16, 2013 at 8:48 PM
    SwimNdrive
    SwimNdrive Member
    CA
    07 SR5
    Sorry to bump the old thread. I am currently upgrading the speakers on my 07 taco and fund a diagram and some notes from internet. Please correct me if I am wrong about this. Here is what they look like:
    LF(+): Pink (P)
    LR(-): Violet (V)
    RF(+): Light Green (LG)
    RF(-): Blue (L)
    LR(+): Black (B)
    LR(-): Yellow (Y)
    RR(+): Red (R)
    RR(-): White (W)
    Tweeters are having the same color wires as the corresponding door speakers.
  4. Nov 4, 2014 at 2:51 PM
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Has anyone confirmed the info above? did it change between 2010 - 2012?
  5. Nov 4, 2014 at 2:57 PM
    fletch97
    fletch97 Professional Window Licker
    NJ
    2013 Tacoma SR5
    Here is the correct info.....
    Front Left = Pink (+) & Purple (-)
    Front Right = Green (+) & Blue (-)
    Rear Left = Red (+) & White (-)
    Rear Right = Red (+) & White (-)
    BTW....this is what worked for me in my 2013. I did some research and then tested to make sure it was correct!
    ThatguyJZ likes this.
