2008 Tacoma Brake Service Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlofthouse, Feb 28, 2016.
  1. Feb 28, 2016 at 7:03 PM
    rlofthouse
    rlofthouse [OP] Well-Known Member
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Been noticing the breaks on my 2008 tacoma have been getting a little squeeky, I don't believe they have ever been replaced (75k miles). I have a few DIY questions: Ive come to the conclusion replacing the break pads is pretty simple?
    1) Best brand of break pads? I hear NAPA pads are pretty good?
    2) Rotors: Whats the rule of thumb for replacing rotors e.g. mileage intervals or millimeter thickness?
    3) Is a break fluid 'flush' necessary?
    THANK YOU!
  2. Feb 28, 2016 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Brake not Break. I know It is anal, but it drives me crazy...
    OEM Brake Pads are the best IMO.
    Rotors if they are not cooked ( blue spots etc ) smooth. I would just measure them and if in spec let it roll.
  3. Feb 28, 2016 at 7:54 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Any idea who makes the brake pads for toyota? I hate buying from the dealers..
  4. Feb 28, 2016 at 7:57 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
  5. Feb 28, 2016 at 8:23 PM
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    I just finished out a set of Wagner ThermoQuiet pads and was very pleased with them. When those were put on around the 70,xxx range, the rotors were turned then also. The next change was around 120,xxx, I went with the PowerStop Pad and Rotor Kit part # KOE 137 and love them. One thing worth mentioning is I followed their break in procedure to load the rotor evenly with pad material. For the money it's a great replacement system. Another thing is to make sure you replace the slide pins and lube them up real good with brake caliper slide grease.
  6. Feb 28, 2016 at 9:23 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    am-autoparts, 89 dollars for pads and rotors delivered, get the ceramic pads which is what OEM is. Just remember to bed them in by getting them hot on the first run. (about 5mi)
    Put these on my truck about 6mo ago and am very happy with them so far.
