2008 tacoma v6 cranks but wont start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bb_claw, May 21, 2015.
  1. May 21, 2015 at 5:47 PM
    bb_claw
    bb_claw [OP] Active Member
    so I have a 2008 Tacoma 4.0l v6. occasionally when its hot it will not start, the truck will crank and crank but will not turn over. the otherday when I was driving home from work I stopped to get gas a few blocks from my house and it wouldn't restart after I filled up. I walked home and came back a few hours later when it cooled down outside and it started first try. when the temperature outside isn't too hot it doesn't really act up and im able to drive it around. today my truck has been sitting outside all day in the hot sun and when I tried to start it it wouldn't start I will wait a few hours and when it cools down outside it should start fine. any ideas as to what is acting up on my truck or things I can check??
  2. May 22, 2015 at 9:18 AM
    bb_claw
    anyone have any ideas why my truck does this sometimes??
  3. May 22, 2015 at 10:29 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    battery?
    heat kills them. how old is it? take a voltmeter to it.
  4. May 22, 2015 at 10:50 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    If its cranking over, its not the battery or alternator or starter. So your left with sparkplugs, fuel pump, or a computer problem. Could also be bad fuel I suppose so maybe run some dry gas through it. Spark plugs are easy/cheap to replace for a second possible fix. Fuel pump and computer problems will be more pricey and difficult to diagnose.
  5. May 22, 2015 at 12:05 PM
    wolfeinstein
    wolfeinstein Well-Known Member
    Orange County, California
    Mean Machine
    Get a Ford or a Dodge
    Lester Lugnut and 12TRDTacoma like this.
  6. May 22, 2015 at 12:10 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Thank for the helpful reply, fop.
    To the OP:
    It's one of three things: Fire, fuel, air. You've got cranking, and to get it hot you had to have it running, so it isn't something physically broken.
    Sounds to me like something specific to the temp or conditions at the time: Think vapor lock, or maybe a tube heated up to the point it expanded and restricted interior air or fuel flow. Some condition that is exacerbated by temperature.
  7. May 22, 2015 at 12:10 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Sounds like maybe your fuel pump?
    Sandman614 and 12TRDTacoma like this.
  8. May 22, 2015 at 4:27 PM
    bb_claw
    The battery seems to be fine. I was thinking fuel pump possibly or something with the ignition, spark. I changed the plugs awhile back so they should be fine. How can I check the fuel pump? Do they regularly go bad?
  9. May 22, 2015 at 4:29 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Not regularly go bad but could have only way to check is by pulling the gas tank out and taking a look at it not sure how exactly to test it
  10. May 22, 2015 at 4:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm going to guess Engine Coolant Temp sensor or crankshaft sensor.
  11. May 22, 2015 at 5:05 PM
    bb_claw
    Ok, would it fail intermittently like that tho? Is there a fuel purge under the hood where I can check for fuel when it won't start?
  12. May 22, 2015 at 5:07 PM
    bb_claw
    I read coolant temp sensor as well. It can't be too expensive, might try there and then crank sensor or fuel pump.
  13. May 22, 2015 at 5:19 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    $20 and $80
  14. May 22, 2015 at 5:27 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I wouldn't think so kinda seems like a sensor is out somewhere with a bad ground or a short in your fuel system not allowing the fuel pump to work properly
  15. May 22, 2015 at 5:32 PM
    gearcruncher
    Canadain bumper technician
    Anyone you know got a scanner ?
  16. May 22, 2015 at 9:04 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Not sure a scanner will help if it's not throwing a code
  17. May 23, 2015 at 7:45 AM
    bb_claw
    I have a scanner but there's no codes. The other day when it wouldn't start I hooked the scanner up and it couldn't connect to the ecu
  18. May 23, 2015 at 7:56 AM
    Xaks
    Xaks
    Oklahoma City area
    Hmmm...it wouldn't start and you couldn't connect? That sounds an awful lot like a ground issue...it would explain why the plugs aren't firing right and the ecu isn't responding.
    However, hunting down a ground that only grounds when the truck is hot sounds like a cast-iron bitch :(
  19. May 23, 2015 at 8:24 AM
    bb_claw
    Ya its a pretty weird situation. Any ideas which grounds I could check?
  20. May 23, 2015 at 9:04 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The answers to all of your questions are contained within the following link: http://www.customtacos.com/tech.old/files/05FSM/
    It is difficult to diagnose problems like this over the interwebz. Check the basics. Battery voltage above 12V? Are you getting spark? Are you getting fuel? Next time it won't start try unplugging your maf sensor and see if it starts, then temp sensor, crank sensor, etc. If it starts when you unplug one of those sensors you found your problem. The ECU will start the engine in "limp" mode with the connector undone, but if it is connected to a bad sensor often times it will not start.
    http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/005006.pdf
    Difficult to start with warm engine:
    Lester Lugnut and DoorDing like this.
