2009, 2010, or 2011 which is more reliable?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jowen15, Mar 6, 2012.
  1. Mar 6, 2012 at 9:00 PM
    Jowen15
    Jowen15 [OP] Member
    I'm looking to buy a used Tacoma and was looking mainly at the 2010 and 2011 Automatic Double Cab 4x4 with the TRD Off-Road package. I need this truck for every day use and dirt biking and was wondering which year is the most reliable and has the least problems, so that I can pick a a more trustworthy truck. I also threw the 2009 in there, but haven't looked at it much.
    :confused:
  2. Mar 6, 2012 at 9:01 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    they are all EXACTLY the same
  3. Mar 6, 2012 at 9:03 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    6 speed or automatic?
  4. Mar 6, 2012 at 9:03 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Take your pick. All can be considered extremely reliable.
  5. Mar 6, 2012 at 10:32 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    X2...
  6. Mar 6, 2012 at 10:32 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Havent had any problems with my 2011 at all
  7. Mar 6, 2012 at 10:35 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    2011 has a different grille , other than that they are all the same truck
  8. Mar 6, 2012 at 10:36 PM
    Jowen15
    Jowen15 [OP] Member
    I've read about gear hunting in the 2010 models. Will this be any big problem?
  9. Mar 6, 2012 at 10:37 PM
    OZ-T
    Peter North
    British Columbia
    No
    I assume you are looking at autos then
  10. Mar 6, 2012 at 10:54 PM
    Jowen15
    Jowen15 [OP] Member
    Yea looking at autos just fixed it up top and thanks
  11. Mar 6, 2012 at 11:51 PM
    leveltwo
    leveltwo Well-Known Member
    Same trucks, same engines, the only thing that matters is the driver of the vehicle. If it was run into the ground its not gonna be as "reliable" as another...
  12. Mar 7, 2012 at 7:29 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Since you clarified automatic look at it this way. Resale value is awesome on these so a 10 and an 11 are going to be priced close. If you can get a better deal on a ten do it but why not pay a few bucks more, grab an eleven that some dealer is trying to get rid of and get all the factory warranties and free oil changes/tire rotations. And if it matters that much to you 2011 has the honeycomb grill and I think nicer dash cluster? GL
  13. Mar 7, 2012 at 7:37 AM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    This was addressed with the accelerator pedal recall. Toyota will update the ecu as part of the recall. The trans had a tendency to drop into 1st gear too soon, causing rpms to go up when slowing below 20mph...like at a stop light or a slow turn. The ecu update fixed this issue.
  14. Mar 7, 2012 at 1:14 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Don't quote me on this because I don't know what years it applies to but don't get one that has Vin starting in "3". Mine is a "3". Made in Mexico :facepalm:Who would have thought Mexico would be bad a making Taco's? Bad joke I know. But all in all I'd just stay away from a "3" for sure because my 2010 has had numerous problems.
  15. Mar 7, 2012 at 1:20 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I heard the 2011's are way better than any other ones. That's just what I heard though... :dancingbacon:
  16. Mar 7, 2012 at 1:20 PM
    Aw9d
    Aw9d That one guy
    Do you have issues with yours because of this? Mine is also assembled in mexico, which I'm not happy about. But I've had no issues on my 2011.
  17. Mar 7, 2012 at 1:25 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    fixed that for ya ;)
  18. Mar 7, 2012 at 1:26 PM
    OZ-T
    Peter North
    British Columbia
    Didn't all the DC production move to Mexico after the 2009's ?
  19. Mar 7, 2012 at 1:28 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Got a 2008 and no issues
  20. Mar 7, 2012 at 1:29 PM
    VolcomTacoma
    Jeff
    NorCal
    Eh...noooo, pretty sure I put 2011...
    Also pretty sure 2012 wasn't listed in OP lol :D
    Obviously the 2012 has WAY to many problems to be included here.
